FORUMS
- 5
| 05-22-2011, 01:53 PM | #1 |
Rigging up a dab aerial
Tried it under the glass roof and rear window
Works well enough for me What's gona be easier to wire up properly, roof or rear window Any one hidden a wire under the roof lining, airbag on the sides ???? Or put an extra wire through to the rear lid ??? |
| 05-22-2011, 07:59 PM | #2 |
In the US, the radios come standard with HD radio reception (a different form of digital audio broadcast). I'm wondering if they use the same antenna, and if so, is it common with those sold where you are? IF so, you may be able to run that into your receiver.
| 05-23-2011, 11:58 PM | #3 |
Tnx, yes there are splitters for that, FM/DAB
Locating the cable might be an interesting task, but a valid point, shall go and find out. P.s. Bought an extension lead for it at maplins, was not keen on the plug on adaptors, so said to the blond youf "i'l cut the connectors and solder the cable in" Her reply "you won't be able to bring it back for a refund" That's blindingly obvious !!! My reply caused offence ![]() |
| Bookmarks |
| Thread Tools | Search this Thread |
