2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
03-21-2024, 06:49 PM | #3213 |
Rep 3,077
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
I did a little coding with BG's Protool, and enabled key fob closing of windows and mirrors, along with the rain sensor closing windows/sunroof. I wonder if that is an always on function and could end up being a parasitic draw though? Also enabled Euro brake force setting... not sure what it does, but Euro...
ChiltiCoatl891779.50 |
03-21-2024, 09:23 PM | #3214 |
Rep 78
Drives: 2015 BMW 535i xDrive M sport
Replaced the windshield cowl today
03-21-2024, 09:43 PM | #3215 |
Rep 3,077
Possibly my least favorite maintenance item. Mainly because I can't imagine a car engineered to have this integral piece fall apart and need replacing on a regular basis! No car I have ever owned has had a piece like this and it infuriates me that I need to replace them.
/rant Last edited by StradaRedlands; 03-22-2024 at 01:25 AM.. |
03-21-2024, 09:48 PM | #3216 | |
Rep 78
ChiltiCoatl891779.50 StradaRedlands5027.50 |
03-21-2024, 10:11 PM | #3217 |
Rep 441
Drives: 2016 F10 BMW 535i M Sport
Yeah it needs to be conditioned to make it last longer, I got to replace mine eventually as well.
StradaRedlands5027.50 Carbon535i369.50 |
03-24-2024, 08:11 AM | #3218 |
Rep 110
Well.... i did a letter delete yesterday, but i landed on a antitank mine....🤦🏻‍♂️ trunk was slightly damaged with a dent(i knew that when i was buying a car) and i decided to remove letters and polish that part, but repairman put invisible coat over all trunk, and over letters so i had to grind that part with water paper and polish. I got 90% i wanted but it looks ok. And today i removed my screen to clean debris and dirt from previous owner, as it was almost unclear to view at bright light. Now the car looks few years younger! And washed it after big mess. Cleaning screen is easy process. Remove trim from massenger side to start button, just hang down, and two torx screws hold plastic blend under screen. Screen is just one connector, easy to pull out. I removed plastic trim, and removed metal frame around screen to clean everything. It was all sticky and purple, like cats scratched it. Cleaned it with fx protect interrior cleaner and microfiber cloth. Just wipe left right and up down with finger. Slight pressure,and it goes.
s_ribs46.50 |
03-24-2024, 01:03 PM | #3219 |
Rep 3,077
Wow zrile that screen looks amazing! I'm going to need to look into doing that! Great car!
zrile100.00 |
03-24-2024, 02:19 PM | #3220 |
DIY Mechanic
78
Rep 130
Drives: 2012 BMW 535i xDrive
Last weekend did an oil catch can and this weekend replaced alternator bolts, weather cowl and all jackpads. I have a 90 elbow to fix the kink in the catch can hose! Just need to find the time.
You can live in a car but you can’t race a house.
03-24-2024, 08:25 PM | #3221 |
Rep 868
My 10 year old '14 LCI F10 535 is not looking too bad.....(picture taken today). It has served me well. Within only 49K miles, tires, battery, oil, air filters & struts/shocks (koni specials) are the only things replaced so far. Haven't even changed the brake pads yet.
I replaced the handle grabs from a G12, to wood ones, and wish that all BMW's came with this version of handle grabs. I use the handle grabs all the time and really don't like the "all" plastic versions. I thought that the grey on the handle would match a bit more closely to the Silverstone Merino Leather color, but the shade is a little off. I might change the plastic color on the handle grabs to either flat black, or Silverstone, or just leave them since nobody looks at them except me anyways. Last edited by M_Bimmer; 03-24-2024 at 11:28 PM.. |
03-24-2024, 11:02 PM | #3222 | |
Rep 5,409
03-24-2024, 11:25 PM | #3223 |
Rep 2,595
M_Bimmer did a full M5 interior retrofit, I believe.
2015 BMW 535xi
03-24-2024, 11:35 PM | #3224 |
Rep 868
Not sure what info you are looking for, but they are F10 ///M5 seats, front and rear. Front seats are ventilated, heated, and massage - working 100%, of course in Silverstone II merino leather.
The seats are accompanied with a 100% full merino leather door cards (top & bottom), 100% full leather dashboard (top & bottom) and 100% full leather center console (top and bottom). Retrofitted power rear sunshade, retrofitted 4-zone climate control, and some other tid-bits back in 2019 after the factory warranty ran out. Last edited by M_Bimmer; 03-24-2024 at 11:45 PM.. |
StradaRedlands5027.50 ChiltiCoatl891779.50 |
03-24-2024, 11:39 PM | #3225 | |
Rep 3,077
03-24-2024, 11:44 PM | #3226 |
Rep 868
...except for the Alcantara headliner, Alcantara rear window shelf/speaker cover, Alcantara Sun visors, and the Alcantara A/B/C pillar upper covers, which would be another $1000 or so (may include shipping), but I've not found a listing on eBay that is worth installing - they all tend to be dirty, worn, ripped or all the above.
Once we get a break from the rain on the weekend, I'll be able to drop the front bumper and quickly rebuild my F10's headlight assemblies. The black rear headlight canisters (buckets), pictured, are new, and will make the headlight repair pretty easy and fast....I don't have to worry about saving the old black headlight buckets, which tend to break rather easily over the clear lens material. Using plastic to protect the lens until I can clearcoat them. Last edited by M_Bimmer; 03-25-2024 at 12:06 AM.. |
03-25-2024, 12:58 AM | #3227 | |
Rep 2,595
2015 BMW 535xi
03-25-2024, 03:02 PM | #3228 | |
Rep 5,409
Your interior is |
03-25-2024, 03:58 PM | #3229 |
Rep 2,595
Less of a "what did you do today" and more of a "whoops"
Had a little slip when taking an exit turn too quick for the wet. Actually goes to show how unsettling the suspension can lead to slip given the right conditions, since you can see that the car was not happy as soon as I hit that pot hole.
2015 BMW 535xi
03-25-2024, 07:12 PM | #3230 | |
Rep 5,409
BTW, what was going on at the left at the end of the video? Looks like a truck may have tried to prove physics wrong and occupy the same space at the same time as the car. |
Unspec1311.50 |
03-25-2024, 11:03 PM | #3231 | |
Rep 2,595
2015 BMW 535xi
StradaRedlands5027.50 ezaircon4jc4565.00 |
03-26-2024, 05:45 AM | #3232 | |
79
Rep 174
M_Bimmer helped me a lot with gathering info when I did my retrofit. |
03-26-2024, 09:40 AM | #3233 | |
Rep 868
...most challenging mod was the 4-zone. ...the easiest mod was the rear power sunshade. ...the most time consuming mod was changing all the leather from dakota to merino/nappa. Last edited by M_Bimmer; 03-26-2024 at 10:40 PM.. |
03-26-2024, 07:44 PM | #3234 |
DIY Mechanic
78
Rep 130
Small upgrade today going from a pre lci base wheel to a lci sport wheel. Thanks to RJV3 for the sale. Excuse my white ass legs. Being stationed in South Dakota hasn’t been good to me. 🫡
