02-25-2024, 10:10 AM | #375 | |
Rep 7
Ok, i am going to order the friction discs: - so i guess i need 4 of them ? - Are there any installation instructions ? - The cheapest i could find was here: https://www.baum-bmwshop24.de/bmw-re...e-34106884839/ - are there variations ? because they are not cheap and ordering a wrong one would be costly :-) tape around spigot: do you have instructions ( pictures, video, ... ) how to do it ? I can at least try :-) spacers: Do you have a link to the spacers you bought ? The tires are non runflat tires. |
02-26-2024, 05:52 AM | #376 | |
Rep 66
And then install the wheel carefully using star pattern to tight gradually until 140N. If after that you notice improvement you can i think order the disc or the spacers https://www.superforma.co.uk/ If you cannot notice any improvement check your rim ,tyre or brake disc Runnout. |
03-13-2024, 08:00 AM | #377 | |
Rep 93
I am trying to figure out a similar problem, it very much resembles these complaints around 120-130 km/h with two different tire brand and size (18” Michelin all season and 19” Pirelli cinturato) As I have it with two different tire/rim size and brands, I wonder if it is a bad coincidence or it is a problem not related to tires. I also hear a pulsating humming noise with slight vibration on steering wheel. I mean, the humming sound is more dominant than the feeling of vibration. The vibration app shows the frequency is the tire rotation speed. But the bearing and axle is also rotating at the same speed. To seek the problem in right place; Anybody dealt or succeeded in this wheel centering problem also heard any pulsating humming noise at these speeds? |
03-18-2024, 02:42 AM | #378 | |
Rep 66
03-18-2024, 12:07 PM | #379 | |
Rep 93
Was the vibration in your case happening in a continuous manner? Mine is as if a wave, rising and going out once a second. So I try to figure out whether I am living the same source of a problem or not. |
03-18-2024, 10:29 PM | #380 | |
Rep 6
I described it in the exact same way to the dealership - it's like a wave that I can feel in the pedals, wheel, and chair but it only happens above like 70mph. It's not constant. So far they straightened 2 slightly bent rims and replaced 2 tires that were out of spec for force balance but zero impact it's exactly the same. Everyone is stumped. Tomorrow I'm going back to the dealership and the shop foreman and service manager want to drive the car to try and figure it out. |
03-19-2024, 04:32 AM | #381 | |
Rep 93
Please keep us updated, I have been searching the cause but could not find anything up to now. |
03-19-2024, 05:12 AM | #382 | |
Rep 66
Based on my multiple test it was wheel related, experienced that with 3 set of different wheels. That i can recommand is to use non rft tyre balanced with hunter road force And use friction disc(with perfect clean and ce!tering mounting)or customer spacer, to prevent micro slipping due to the high tolerance of the wheel on the wheel hub And finally never overinflate your tyre , it increase the road force. |
03-19-2024, 12:39 PM | #383 | |
Rep 93
03-20-2024, 08:08 PM | #384 | |
Rep 6
Only thing he suggested was to switch to non run flat tires like many others here have mentioned. I even showed him this thread, he confirmed I'm not the first person to mention this problem to him and that it's something owners of this platform just have to get used to. He apologized profusely and said he wished he could offer me a fix. Crazy that a car of this price has this kind of vibration and we are supposed to accept that it's "normal". |
03-21-2024, 12:58 PM | #385 | |
Rep 93
The forum users are much more beneficial for finding solution considering the useless dealers. |
03-21-2024, 01:45 PM | #386 |
Rep 887
I had vibrations above 70mph and were present with both my winter and summer wheel setups. More so with the winter as my 759s have been bent and straightened a few times. After I replaced my cracked Guibo I would say 90% - 95% of said vibrations disappeared. This platform seems to be sensitive in that regard lots of people complain about it.
03-21-2024, 02:10 PM | #387 |
Rep 5,409
My two F10's (previous 2012 and current 2014; both 535i's) and my current G30 (2019 540i) are smooth into the triple digits (in Mexico, of course!); no vibrations at all. That's on both ROF's & non-ROF's. IMHO, blaming the chassis is a cop-out. I thought I read somewhere that the solution was realigning the orientation of the front shocks. I could very well be wrong, and this was for a different car, so don't quote me.
03-22-2024, 02:36 PM | #388 | |
Rep 93
03-22-2024, 02:37 PM | #389 |
Rep 887
