2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications My n63 intake build from stock to complete front facing CAI
      04-29-2021, 02:02 PM   #23
AnotherM
Cole
Drives: 2016 m5 CP
Originally Posted by 1Kurgan1 View Post
It looks great! I was wondering, from what I'm seeing, you must have attached the filter right to a silicone hose. Did you happen to cut a small strip of 3" tubing to slide inside the silicone hose then have both the hose and the filter attach to that?
I haven't seen anyone address this. And this is something I have also seen in other posts, but no one ever goes into detail on how or why? Can we just unplug the MAFs? Does tuning need to be done?
I mean I can unplug the MAF on my LS Chevy and it'll drive fine, but it just goes to stock fuel maps when you do that. But that is a very simple engine.
If you unplug the MAF, you will get a code. I would guess the car would run terrible.
Yes, i cut a small piece of 3" pipe to attach the filter to the 45.
      04-29-2021, 02:57 PM   #24
mcdanielvzw
mcdanielvzw's Avatar
168
Drives: 2021 X3 M40i (times 2)
Even though I've got a TU which I see people say doesn't use the MAF, I'd still want to cut the housing so everything is copacetic. For a fee, would you be willing to duplicate the cutting and tapping? ��
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights, 50th anniv badges
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      05-03-2021, 07:44 PM   #25
1Kurgan1
Drives: 02' x5 4.6i | 99' 540i/6
Originally Posted by AnotherM View Post
Extended the intake into the grille
4-3" 45
2- aluminum 45
So I picked up a list very similar to that and it leaves me with some questions after trying a mock up.
Did you oblong out the 3" 45 degree? Because that thing is not fitting in that passage that far. Also why 4x 45's? It seems like the ones up front should be 90's. And how long are the 45's you got? I picked up a 90 and was just going to cut it in half, but I'm still missing a few pieces, so I can't get a full mock up, but it seems like it will be short.
      05-05-2021, 10:51 AM   #26
AnotherM
Cole
Drives: 2016 m5 CP
Unfortunately, i dont have the car anymire ao i cant measure them. I tried 90s in the front, but it placed the filters to close to the cross supports.
It was a complete pain in the arse to get the 45's through the passage. What i did to get them through was:
Put the 45 pipe in the passage and align it as if it was all attached so that you can mark it and the 45 coupling to assemble outside of the car.
Take the pipe and the coupling, align the markings and assemble them with clamps out side of the car. Tighten them up, but make sure the bolts on the clamps are along the top so they fit into the passages.
Use some vaseline or lubricant on the coupling and pull it through the passage from the engine bay side towards the front. It will be a complete pain, but it fits.
Next attach the upper 45 coupling to the maf housing and 45 pipe. Tighten clamps.
Next, install a small piece of 3" pipe (i cut this small section off of the other pipe) into the airfilter and tighten the clamp.
Lastly, install the filter and pipe into the intake and tighten the clamp.
I can tell you that i definitely got pissed off a few times, walked away and had a beer while staring at it. Just take your time and patiently wiggle it through the passage.
      05-05-2021, 09:26 PM   #27
1Kurgan1
I'll have to try and lube her up, lol. I've just been mocking things up a bit. It looks like you must have also cut up a 3" silicone tube to fit between the MAF housing and the intake tube. I started testing fitting and could damn near through a cat between them, but then checked one of the silicone elbows and it fit nice inside of there.
So it looks like I have a few more odds and ends to order and will have to get to modifying my MAF housings so the sensors go to the right depth. Do you know if it matters if the housing was rotated so the sensor was hidden on the back side? Or do MAF sensors need to be close to horizontal?
Either way, here's my first test fit
And here's as far as I managed to get the 3" pipe with the 3" silicone 45 over it, lol.
      05-07-2021, 10:59 PM   #28
BimmerHausPerformance
BimmerHausPerformance's Avatar
514
Drives: F10 S55, E93 M3, E89 N54
2012 BMW Z4  [0.00]
2011 BMW 535i  [10.00]
Here is a good way to get them through that small passage.
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      05-08-2021, 09:13 AM   #29
AnotherM
Cole
Drives: 2016 m5 CP
Hey, i was just looking at your pictures and noticed a huge problem. You jeed to tighten the meth injectuon bung on your chsrge pipes right away. Those are avout to push out and. Ause a huge boost leak
      05-08-2021, 09:14 AM   #30
AnotherM
Cole
Drives: 2016 m5 CP
Also, if you dont modify the maf housing like i did, you will throw codes for bank Rich.
      05-09-2021, 01:10 AM   #31
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
The last 45 degree couple I went with a 90 and trimmed it a bit off (like 75 degree) but I did that for the look of the filters. Haven't had a MAF fault nor have I ran lean at all in 2 years.
Heating up the plastic hole to get through to the kidney grill area helped a ton too.
I don't think the orientation of the MAF pipe matters, I have ran them on both sides but then again I have not upgraded to the X5/M5 inlets just because if it's not broke why fix it kind of deal.
You also need to replace you turbo coolant lines ASAP, I currently have the brass T with rubber tubing but Monday I will be installing my new AN10 fittings and steel braided lines (mainly for looks but also durability). Picture is just the mock, nothing is tightened yet. But I promise, 7 out 10 of us have had cracked or leaky plastic T's and had to change it after they leaked.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
Hornet-01165.50
      12-03-2021, 01:22 PM   #32
Hanzo550
Hanzo550's Avatar
Drives: 2011 BMW 550i xdrive M Pkg
Where did you purchase these fittings?
Hornet-01165.50
      12-08-2021, 07:47 PM   #33
550bye
550bye's Avatar
Drives: 2011 550i
I think eBay, you can buy the whole kit with just black fittings and the hose or individual purchases with the type of hose and the color of fittings you want. But just google either AN8 or AN10 fittings and you will find a million different types and color variations
2011 550i (N63)
      12-08-2021, 10:51 PM   #34
musclesmarinara75
musclesmarinara75's Avatar
Drives: 2013 BMW F10 N55 535i XDrive
2013 535 XDrive  [9.75]
GODDAMN.. That dude needs to forget about the intake and trim his fucking toenails... WTF.... or put on some shoes
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
      08-23-2023, 02:11 PM   #35
slobo7x
Drives: 2016 550 F10
I still don't understand the PCV system used in your 2012 550.. Did you order it from a 750 engine or? I see no crossover pipes in the middle at all.
      09-16-2023, 03:02 PM   #36
slobo7x
Those air inlet part numbers are for the v8 version of f15/f16,
The x5M has a different inlet tube, which one are you using exactly?
The reason I ask my 2016 n63TU oil filler tube has to be removed for this to fit,
Do I need to buy the x5M inlets instead?
      05-09-2024, 03:08 AM   #37
hasanalothman
Saudi Arabia
Drives: bmw 650i 2014
Accidentally posted in the wrong section before.
I'll make this short and to the point. I, like many other n63 owners paid a good amount for the ARM intake. Now, the intake is great quality and I'm not saying anything negative about it.
But........I decided to try something i haven't seen done and it worked perfectly. I ordered the intake ducts from an x5m which point forward and installed them with an maf housing from a chevy cruz and a cone air filter. It sounds much better than the ARM intake, definitely has smoother throttle response, and only cost half the price.
X5m intake ducts on amazon-$165 for both
13717638569
13717638568
https://www.amazon.com/dp/B00XKU78CU...p_mob_ap_share
Maf 3" housing from Chevy cruz- $80 for both
https://www.amazon.com/dp/B07T9FQVJN...p_mob_ap_share
Cone air filter-$60 for both
Total- $305
Pics below. I am planning to extend them into the front grills later. One of the biggest advantages Is I can now change sparkplugs and coils without removing anything.
I know my filters look a little beat up and they are going to be replaced shortly.
many thank for the try this is the best way to have intake.
i live in saudi arabia which the weather in here is way worst than you could imagine!!
i wish that you have a kit and sell it better than the ridicules prices to have it as a kit.
two humble comments :
1- first is the option to make it front facing isnt needed in my opinion, there are scoops like AFE will make almost the same temp when you drive.
2- sell the kit to us ready without us having the issue to tap and cut 1/2" from the MAF duct
thank you bro for what you did that's the best intake in the market
