2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20 inch Wheel Fitment Question.
      03-13-2018, 03:21 AM   #23
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Originally Posted by Techgeek80s View Post
Can I run 20x10.5 in the front with no fender modding and if so I can only assume I need to run a specific tire size keeping in mind I have an x drive to be able to pull it off. The only thing is that I live in jersey and the streets are shit. Iv run through 4 tires in the last 6 months and they have all been sidewall damage/tears. The wheels I’m looking at in order to get the look I need to run 11s in the back. Also if I’m looking at a wheel with a lip does that change anything on the fitment in order to clear the calipers?
It would depend on a lot of things but I would say you cant run a 20x10.5 up front without modding the fenders or an m5 front end conversion. Im sure someone will say they are running an 11" in the rear and a 10.5 upfront with no mods and no rubbing which is usually bullshit and never verified with pics and they say they are doing it with ridiculously wrong et's. I would go with a 20x11 et +46 and a 20x9.5 et+31 which should fit flush without any fender mods. Remember most people who claim these wheel sizes often never post again or show any proof they dont rub. What wheels are you looking at and what is the offset range?
      03-13-2018, 06:28 AM   #24
wrecked2001
Drives: 2013 535i Msport/Imperial Blue
Originally Posted by lsturbointeg View Post
i'm running et 38 on a 21x11. so take a .50" off i think it'll tuck? those are sweet looking wheels bro! what color scheme are you planning on going with? is that a true 2-3 piece wheel?
Niche does make a version of this wheel in a three-piece construction, with more concavity too.
      03-13-2018, 09:23 AM   #25
Techgeek80s
Drives: 2013 silver 535xi
I have confirmed with my Shop that 20x10 will fit in the front I just don’t know about the et
      03-14-2018, 07:28 AM   #26
remmib
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
I've seen an F11 in the (on bags I believe) with 20x10.5 ET20 in the front. Very stretched tires though, 245 or 255.
      04-16-2019, 09:16 AM   #27
Lukaas54
France
Drives: BMW F10 530d
Originally Posted by dadysev View Post
Quick and easy.
20x9 front ET 35 - I know it will fit
20x10.5 rear ET 35 - will it tuck in with 295/30/20 tires?
Hey,
U have fit your wheel ?
9x20 ET 35 front is ok ? No issue or rubbing ?
Lukas
      04-16-2019, 08:57 PM   #28
KEN210
China
Drives: F10/18 - 528
Quick and easy.
To get a 20x10.5 +35 to tuck you will need to run negative camber and a 285 and it will rub on a hard dip. For perfect fitment with no rubbing and no inner tire wear from negative camber the rear will need to be atleast a +40 and a 285. If someone tells you it wont rub and tucks with a 295 with a +35 on a 10.5 they dont have that setup or they are guessing. I've tried that setup and it rubs when it tucks.
Had similar issue. I put a 275/35/20 et: +35 Niche and had to do a bit of negative camber due to rubbing though I was wondering why it was only on the right side.[IMG][/IMG]
      04-26-2019, 04:55 PM   #29
Ozzy24
Drives: 2015 BMW 528i Xdrive AWD
Im new to the whole buying wheels thing. I drive a 2015 528i xdrive. The ones im trying to get are staggered
Front: 20x8.5 +35
Rear: 20x10 +38
I dont know much about all of this, would these work or would it cause problem? i know the specs say something completely different.
      04-26-2019, 05:28 PM   #30
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
That setup will fit on F10.
But you will probably like 10-12mm front spacers to match the much more aggressive rear wheels.
Do you plan to use 245/35-20 front and 285/30-20 rear tires?
      04-27-2019, 06:36 AM   #31
Ozzy24
I'm not really sure.. I'm still trying to figure out which offset will actually fit my car without it rubbing.. the specs only go up to 9 width and the offset is 44 so I'm not sure how to differentiate when it comes to 10
      04-27-2019, 10:40 AM   #32
remmib
remmib's Avatar
Norway
1571
Changing offset from ET44 to ET38 means the wheel sits 6mm more out/more aggressive. This is with the same wheel width.
Going from an 9" to 10" wide wheel add half an inch on each side of the wheel from center. This means you add half an inch more aggressive fitment with the wider wheel, plus the 6mm from the offset change.
So half an inch is roughly 13mm + 6mm = 19mm more aggressive fitment with the new rear wheels.
      04-27-2019, 12:07 PM   #33
Ozzy24
Makes sense. One more question.. I found another set of wheels I actually liked better.. they're staggered
Front: 20x8.5 +30
Rear: 20x9.5 +38
The specs for my car say (not staggered)
20x8.5 +33 standard
20x9 +44 standard
Just by looking at these numbers do you think I will run into any issues such as the front sticking out further then that back or running.. or does the front even with the back because of the difference in wheel width?
I'm not very knowledgeable in cars in general especially something like this so I'm not sure where else to go lol
      04-27-2019, 12:14 PM   #34
remmib
remmib's Avatar
Norway
1571
Front: 20x8.5 +30
Rear: 20x9.5 +38
20x8.5 +33 standard
20x9 +44 standard
Those fronts will fit better the the previous wheels in question.
      04-29-2019, 06:01 PM   #35
chmsalman
chmsalman's Avatar
Drives: 2014 F10 535i x-drive
I can confirm 20x10.5 et35 with 295 won't work on the rear. Thought I did enough research but obviously not. I've got fender rubbing on the sidewall with bumps.
Sitting at a wheel customizing shop right now lmao - they're machining off some material to adjust the offset to about 36. Hope it helps! Really didn't want to roll fenders and chip paint. Negative camber is ridiculous on 295s so not doing that.
      04-29-2019, 07:02 PM   #36
Bigfred41
Drives: 2014 bmw 528i
Adv 1 wheel help 2014 bmw 528i m sport
20x9.5 +24 255/35/20
20x11.5 +37 295/30/20
These came off my brothers 2016 m4 coupe was wondering if they would fit my car with a little bit of cambering in the rear.
      05-06-2019, 10:17 AM   #37
716535i
Drives: 2011 BMW 535i
Absolute newb here...
Dont want to hijack your post. Just created my account a few minutes ago and was going to buy some 20' Ferrada Fr2 wheels for my 2011 535i
continental all season tires 255/35R20
20/8.5 and 20/9.5
5x 120
Slight concave
Comes with TPMS
Will these fit correctly?
And will i have any issues down the road with putting a wheel/tire combo like this on?
Will it throw off any of the computers or wear the components faster?
Thanks for any help!
      05-06-2019, 01:15 PM   #38
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
Why would you like to run square tires on staggered wheels?
      05-13-2019, 08:11 PM   #39
716535i
For me? If so, it's cause I don't really know what im doing when it comes to which combination of wheel size to tire is correct.
      05-14-2019, 12:17 AM   #40
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
The good thing with square wheels and tires is that you can rotate front to rear and get more even wear.
With staggered wheels you can fit wider rear tires, either for increased traction or if you like the look.
Make this decision first, square or staggered wheels. Then we can help you recommend tire sizes for the wheels you like to run.
      05-14-2019, 07:24 AM   #41
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I've never seen a square setup on staggered wheels before? I think the rears would have a stretch to it
      05-14-2019, 10:31 AM   #42
sbechard7
Drives: BMW 535i
2012 BMW 535i  [0.00]
20" Wheel fitment question
I realize there are a lot of posts out there, but I'm trying to just find the answer to which wheels to buy without pouring through several posts.
I am looking at either 20x9 Front and 20x10 or 20x10.5 rear wheels. The offsets are all over the place and I want a flush fit without any rubbing issues.
Here are 3 of my options:
Set 1
20x9 (et30)
20x10.5 (et40)
Set 2
20x8.5 (et 30 or 40)
20x10 (et 40)
Set 3
20x8.5 (et 35)
20x10 (et 40)
I was planning on going with 245/40 front tires and 285/30 rear tires.
Feedback and pics would be greatly appreciated!
      05-15-2019, 08:04 AM   #43
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
To give you some input the following setup's will be fairly flush on a non lowered F10.
F: 8.5x20" ET25, 245/35-20
R: 10x20" ET40, 285/30-20
F: 9x20" ET30, 255/35-20
R: 10.5x20" ET45, 295/30-20
If the car is lower than OEM suspension, the offset can also be slightly lower due to the camber effect.
      05-15-2019, 10:14 AM   #44
lsturbointeg
here's what OEM 356's look like lowered with no spacers in the front or rear
20x8.5J ET33 front
20x9J ET44 rear
