2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Pics of lowered 5's on 408M's?
      08-29-2022, 01:55 AM   #23
Blue Angel
Blue Angel's Avatar
Drives: 2011 323i and 2016 535d
Originally Posted by brad850csi View Post
Originally Posted by Blue Angel View Post
343m wheels on F10 often rub even with 275s, requiring additional negative camber. I'm not sure if they're rubbing the steel fender or the composite liner, but several reputable members here have had the issue.
Hmm, I thought I'd seen the good majority with 343m running 285 tires - no chance you're talking about M6 wheels with a 19mm offset instead of the F10 M5 34mm?
The M6 wheels are comically wide on an F10, they are not even close to fitting with a normal size tire.
Apparently rear ET34 M5 wheels will rub with 285s but it seems to be camber, ride height and tire profile dependent (some tires are wider and/or more square in the shoulder than others for a given size).
