2010 2011 BMW 5 Series Forum F10 Anyone successfully coded F10 in the UK? |
10-02-2017, 06:20 AM | #507 |
Rep 32
Can anyone confirm that this regen_schliessen works on an F10 ?? I code this last week on my F10 from 2016 and yesterday i had my rooftop tilted up when it started to rain . I then activated the automatic rainsensor but the rooftop did not close, even tried to open the roof top completly and nothing happend. Did i do something wrong or is there another thing i have to code for this to work ?
Thank you |
10-03-2017, 06:36 PM | #508 |
Rep 96
From one of the F10 cheat sheets kicking around:
Enable key fob and driver side door handle to fold mirrors and close windows and moon roof: CAS => 3003 => KOMFORTSCHLIESSUNG_FB => aktiv CAS => 3003 => KOMFORTSCHLIESSUNG_PA => aktiv FRM => 3020 => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN => aktiv To change mirror fold delay CAS -> 3003 -> KMFRT_SCHLIESSEN => Werte= 05 for 0.5 sec, 0A for 1 sec, 0F for 1.5 sec
F10 LCI 535d (313PS) M Sport
JLR19691882.00 |
10-04-2017, 08:37 AM | #509 |
Rep 32
I am looking if there is a way to get the side mirrows to start heating when i push the defrost button for the rear window. My F10 sleeps outside and last week there was allot of fogg in the morning and i could not see anyting true the side mirrows . After 10 min my rear window was clean but the side mirrows where not. I cant believe that such a premium car cant heat the mirrows witouth the temperature beiing below 5C celcius. I fount this entry but dont know what it means.
Thank you |
10-06-2017, 08:12 AM | #510 |
Rep 49
Hi all,
My car has folding mirrors (you press a button inside the car) which I would like to add to car locking/unlocking - is there anyone who can do this local to me? (Milton Keynes way). Also it seems some are able to use the remote fob to do this, what is the sequence as I believe mine just opens/closes the windows.. |
10-06-2017, 03:13 PM | #511 | |
Rep 7,000
10-08-2017, 12:27 PM | #512 | |
Rep 7,000
Also changed the angle of wing mirror dip and can auto fold at 40mph when driving down country lanes. Video in motion is also working and lots of other improvements |
10-09-2017, 03:59 AM | #514 | |
Rep 49
Does that mean you can open them when you unlock? I presume if you hold unlock it will global open the windows... |
10-09-2017, 04:21 AM | #515 | |
Rep 7,000
I have just coded the car so it folds mirrors on lock. |
10-09-2017, 07:05 AM | #516 | |
Rep 1,207
Send a screenshot of E-Sys. after you have connected, read all ECUs, filter by CAFD.
10-09-2017, 07:08 AM | #517 | |
Rep 1,207
However, I presume you are aware that it is not road legal to have fogs on all the time. Is it really worth the risk, rather than having to press a button - when needed.
JLR19691882.00 |
10-09-2017, 07:11 AM | #518 | |
Rep 1,207
You run a small risk of damaging your folding mirror motors. Assume super cold conditions, mirror mechanism is almost frozen. You lock your car, and the mirror try to close; and you end up damaging your motors or plastics being broken. My suggestion is to have a little more control. The difference between 0 and 0.2 is negligible, but will give you the ability to not close if not needed.
JLR19691882.00 |
10-09-2017, 07:13 AM | #519 | |
Rep 1,207
10-12-2017, 03:14 AM | #520 |
Rep 49
Quick update, it turns out if you lock the car and then hold to fold the mirrors then the car will automatically unfold them when you unlock, with just a single short press.
So you don't have to hold and activate the global opening. |
10-14-2017, 04:35 PM | #521 | |
Rep 32
Thank you. |
10-15-2017, 03:38 PM | #522 |
Rep 1,207
Yes. You are right. I had (mistakenly) assumed that you had the comfort seats.
10-16-2017, 06:41 AM | #523 |
Rep 8,114
Why on earth would you want to do that?
Ian
10-16-2017, 07:08 AM | #525 |
Rep 8,114
With bi-xenon headlamps on full beam you wouldn't even notice the fogs being switched on. If I had my way, fogs would be illegal anyway - hateful things.
Ian
JLR19691882.00 |
10-16-2017, 08:12 AM | #526 |
Rep 7,000
Have just coded the HK sound to Bang & Olufsen
The sound stage is improved and the quality is better It's never going to match the actual quality of the system with the correct speakers and amps but it is better |
10-16-2017, 10:19 AM | #527 | |
Rep 1,207
B&O Expanded: Off Fader +2 Treble +4 Bass 0 (or +1)  100Hz -2 200Hz -1 500Hz 0 1KHz +2 2KHz -3 5KHz +4 10KHz +6
10-16-2017, 11:36 AM | #528 |
Rep 7,000
