2010 2011 BMW 5 Series Forum F10 Stainless Steel Brake Lines |
06-02-2020, 08:15 PM | #46 |
Rep 1,456
Drives: F10 S55, E93 M3, E89 N54
Making some progress... new pads coming, I hope these ones fit!
Everything sand blasted, primed and painted. Calipers will be red, spring retainer is black. I figured with having everything pulled off, now was the time to paint them properly. |
ezaircon4jc5203.00 lsturbointeg9188.00 |
06-02-2020, 09:59 PM | #47 |
Rep 148
Thank you! And actually it was sprayed out of an actual spray gun. It was supposed to be candy apple red but I believe due to the way the calipers arent smooth, the sparkles underneath didn't show through as well. I also got the engine bay braces painted the same color and those came out more "candy apple red" like.
lsturbointeg9188.00 Sylverlee151.00 |
06-03-2020, 05:11 AM | #48 |
Rep 14,521
hey dude! did you swap out all the brake lines first before you bleed? i'm trying to decide where to start first? since the rotors and pads are all being swapped out
06-03-2020, 09:07 AM | #49 | ||
Rep 148
06-03-2020, 10:08 AM | #50 |
Rep 1,456
Well... I don't know another way to really do it. You disconnect the brake lines and you get fluid everywhere - just gravity bleeding. So that's where I'm at right now in those pics.
Then I'm replacing the brake lines on all 4 corners after painting everything up and the next step I'll do is to use the pressure bleeder to introduce the new fluid once everything is in place. You have to bleed from the furthest corner 1st working your way to the closest. And since I'm a 6sp I'll do my clutch line too. Hopefully that works and I don't get to where ckaul is at! |
06-03-2020, 01:17 PM | #51 | |
Rep 148
06-03-2020, 09:49 PM | #52 |
Rep 14,521
Was able to get the lines installed no problem. Ran out of daylight so I'll wait til morning to do the brake and bleed.
06-05-2020, 07:07 PM | #53 |
Rep 1,456
06-05-2020, 07:09 PM | #54 | |
Rep 148
06-05-2020, 10:46 PM | #55 |
Rep 1,456
06-06-2020, 03:23 AM | #56 |
Rep 14,521
okay been driving on these for a couple of days now. so far no problems. honestly i wouldn't be able to tell you if these are an improvement over OEM since i swapped out the rotors and new pads as well. i feel there's plenty of bite but i couldn't tell you if the stainless lines helped. i'm sure they're an improvement over the stock and it's probably helping overall with conjunction of the new rotors and pads. These were straight plug and play as they installed right back into factory bracket locations. they do look very nice from pure aesthetics which is a plus for me!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 06-06-2020 at 03:29 AM.. |
ezaircon4jc5203.00 |
06-06-2020, 08:42 AM | #57 |
Rep 1,456
What kinda discs and pads did you get? Overall how is everything compared to stock?
06-06-2020, 09:52 AM | #58 | |
Rep 14,521
https://www.cquence.net/
06-07-2020, 11:15 AM | #59 |
Rep 1,456
ok so with a normal power bleed I cannot get a firm pedal. I'm assuming the full drain due to pulling the lines, vs. a normal flush, will require to follow the ISTA bleeding procedure. Is this what you did lsturbointeg ?
06-07-2020, 11:42 AM | #60 |
Rep 14,521
i did exactly what Kies Motorsports did on their DIY brake flush Youtube video using the Power Booster. they didn't mention anything of having to perform ISTA procedure afterwards. my pedal feels pretty firm. i'm wondering if you let too much brake fluid drain out when you swapped your stainless lines out? i didn't notice much air in the lines when i cracked the bleeder valves open. i've already done some pretty nice pulls and when braking i have yet felt any issues with braking. the braking response feels pretty good. i know right after i finished installing the brakes when i started the car i pumped the brakes a few times and the pedal immediately firmed up!
06-07-2020, 11:51 AM | #61 | |
Rep 1,456
06-07-2020, 01:20 PM | #62 | |
Rep 14,521
06-07-2020, 01:24 PM | #63 |
Rep 1,456
On no, I did not drive it cause the clutch pedal went soft, I just got ista installed, running and connected to the car. Now just trying to learn how to trigger the bleed procedure, lol wow.
06-07-2020, 02:03 PM | #64 |
Rep 14,521
ah so pretty much you don't have brakes than lol! i hear ya! so the pedal is completely soft than? is ISTA a program you have to download from the internet?
06-07-2020, 02:25 PM | #65 |
Rep 1,456
From bimmergeeks yes, dealership software. I would say you have to be fairly computer savvy to get it to work. Need to set up you device manager and run command prompts. It is a hacked program.
06-07-2020, 06:14 PM | #66 |
Rep 1,456
Ok, my obdII port has sketchy connectivity or maybe it is the cable, I dunno but even after following ista working around losing connectivity, I don't have brakes. My clutch is back though. Taking it to an indy tomorrow for a flush so he can show me how to do this.
