2010 2011 BMW 5 Series Forum F10 G Plus Intercooler Install DIY |
04-07-2020, 06:38 PM | #67 |
Rep 14,521
Appreciate it guys! Thinking about doing this next
04-07-2020, 06:45 PM | #68 |
Rep 217
I have less than 50 miles on mine but it feels strong and is leaking free so far. I have to go to work Thursday which takes be by my ethanol station. I bet the E30 map will be bonkers. So glad I finally pulled the trigger on the Gplus before it really starts to warm up.
lsturbointeg9167.50 |
04-13-2020, 11:10 AM | #69 | |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
What do you have that allows you to run e30, or are you just doing that on stock components? |
04-13-2020, 09:52 PM | #70 | ||
Rep 161
Drives: 2015 535i
2015 F10 535i
FBO BM3 Pure Stage 2 Dorch Stage 2 HPFP E50 tune by Cary Jordan EOS EkP Module Walbro 525 LPFP Variant Argon 20? Wheels E60 M550i Sold “Im a crazy car guy” If it has a motor, it has my attention |
04-23-2020, 01:36 PM | #73 |
Rep 2,595
Probably still eBay
2015 BMW 535xi
04-24-2020, 10:57 PM | #74 |
Rep 96
Just saw the lowest price listing I was watching had 1 left in stock so I put my order in. Excited for it to arrive. I’ll be doing DP, CP and this in one shot; stoked to go stage 1 to 2+.
04-29-2020, 07:38 AM | #75 |
Rep 668
HECK YES. whole different car
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
04-29-2020, 09:52 AM | #76 |
Rep 109
Let me know how the install goes.... I'm in westlake and was thinking about doing this as well.
04-29-2020, 10:11 AM | #77 | |
Rep 96
So assuming I have the car back late next week I’ll probably have it done by the weekend. I wonder if we have seen each other around! I’m about to PM you a pic of my car. |
04-30-2020, 07:36 PM | #78 |
Rep 305
After a year of purchasing this Gplus intercooler I finally had the chance of installing it today. Like what everyone says, it's a tight fit and a PITA to install. Wouldn't want to do another install. Ran into a few issues like having a hard time undoing the driver side lock collar. Whenever I undo one side the other side slips back in. So I recommend using two flat head to undo them at the same time. I thought sliding out the stock intercooler was going to be easy because it came out halfway but I was wrong. The other half got stuck so bad that when trying to wiggle it out I dented up the back my ac condenser pretty bad but I think it should be okay but only time could tell.
When installing start with the driver side first since the oil cooler line runs there. Get the intercooler up and around the cooler line then slowly maneuver it up halfway then move to the passenger side and slide it in halfway until both side are about even. Place a jack under the passenger side to support it while getting the other half of the driver side up. Once the driver side is fully in place I used the jack to slowly jacked the passenger side into place. Sliding the chargepipes back onto intercooler was a pain, I fought with it for 30 minutes and decided to take off the radiator fan. Once I took of the fan it literally took me 20 seconds to wiggle both side on from the top. So like in the previous post I highly recommend removing the radiator fan first to give you room to work. I would rather install suspension any day than doing intercooler installation. |
04-30-2020, 08:41 PM | #79 | |
Rep 2,595
2015 BMW 535xi
04-30-2020, 09:24 PM | #80 | ||
Rep 14,521
04-30-2020, 09:29 PM | #81 |
Rep 305
You are right and I could 100% agree. Not taking out the radiator fan first was my mistake. I thought I could do it without removing it until trying to install the chargepipes onto the intercooler. Once you remove the radiator fan the driver side chargepipe moves freely because the chargepipe is held onto the radiator fan with a t25 screw.
05-02-2020, 01:16 PM | #82 |
Rep 96
I just finished installing the GPlus. Definitely a tight fit, but nothing crazy, I didn’t remove the radiator fan. My best advice is to get the driver side just up and over the oil line first, then work both sides up together. My passenger side inlet was very snug against the subframe but just wiggle it up.
As for the hoses, I found it easiest to grab the hose with my right hand as I hold the inlet/outlet on the IC with my left hand and maneuver them to mate. |
05-05-2020, 10:31 PM | #83 |
Rep 617
Installed my gplus two day ago and I've definitely noticed more consistent IATs and definitely not as high anymore either. Install was easy and I did it by myself. Hardest part was getting the piping to fit back onto the intercooler. If you have big hands you're SOL. Took me about two hours by myself.
05-06-2020, 03:29 AM | #84 | |
Rep 14,521
05-06-2020, 12:22 PM | #85 |
Rep 617
05-11-2020, 05:51 PM | #86 | |
Rep 418
MHD stage 2+ needs better chargepipe, intercooler and less restrictive downpipe. |
05-12-2020, 07:40 PM | #87 |
Rep 88
Anyone happen to have the bracket dimensions, or that have not installed it yet and can take measurements for me. I purchased an open box unit but it did not have the brackets unfortunately. I know some people have just fabbed some up. I would like to do so before I get around to installing it.
Going Stage 2+ this week. Got my DP, IC, and will upgrade software. Can't wait! |
05-14-2020, 08:39 AM | #88 | |
Rep 14,521
