2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
09-08-2016, 07:44 PM | #67 |
Rep 8,364
09-08-2016, 11:04 PM | #68 |
Rep 5,409
09-08-2016, 11:18 PM | #69 |
Rep 8,364
Yes. It should show up in idrive. Admittedly, I have only coded the function remotely so I have never seen it work in person.
06-27-2017, 11:09 AM | #74 |
Rep 8,364
06-27-2017, 12:10 PM | #75 | |
Rep 94
so it's mean I'll find all things related FEM Body in FRM/CAS. right |
06-29-2017, 09:52 PM | #76 | |
Rep 8,364
F2x/F3x/F8x has REM. Many of those are in JBBF on an F010. There are Cheat Sheets and Launcher Cheat codes as well as BMW Coding Database for additional assistance. |
myszano118.50 |
07-21-2017, 07:39 AM | #77 | |
Rep 94
Try to inject cafd files but unsuccesfull. Please advise. |
07-21-2017, 09:41 AM | #78 |
Rep 8,364
"Doesn't map to item" means you selected incorrect E-sys connection target. The ethernet errors usually mean you are not running engine to provide adequate power/communication to all ECU's.
07-21-2017, 04:56 PM | #79 | |
Rep 94
Please advise how I should connect f10, or f30, its any diffrent how to connect? Thanks |
07-23-2017, 04:58 PM | #81 |
Rep 94
What about other models, how to connect 1-7series?
07-23-2017, 07:33 PM | #82 |
Rep 8,364
07-25-2017, 01:19 PM | #84 | |
Rep 8,364
Coding: Latest Software Links |
Bruno11219.50 |
07-25-2017, 01:42 PM | #85 | |
Rep 107
08-07-2017, 07:31 PM | #87 |
Rep 231
I coded the Sport Display on my 2011 F10 535iX. It showed the units of kW for power and Nm for torque. When I floored the car, the torque meter maxed at 400 Nm which is about 300 ft-lb that matches my car's spec. Recently I coded the hp and ft-lb units for the Sport Display. However, when I floor the car, the max torque still reaches the the scale of 400 which now should mean 400 ft-lb. Am I missing something? Or the Sport Display is just imitative?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
