2010 2011 BMW 5 Series Forum F10 The Night Photography Thread |
01-13-2012, 10:10 PM | #969 | |
Rep 7,389
The 7D is an amazing camera and one of the best values available to the serious shooter. Dave
01-13-2012, 10:23 PM | #970 | |
Rep 5,114
what happend is because of the pin system, I ended up bending one in my computers card reader. the bent pin then went into the card sideways and tore it apart inside. it took me about 2 days to get all the pictures off of it, I had to stick a sewing pin inside and try to move the metal contact points back into place and pulled the bent pin out of my computers reader and was eventually able to read them. I tryed 3 different readers, and only managed to extract the remaining files on one of them, and funny enough, it was the reader that was missing a pin. I sampled around a bit with other cards after to make sure the reader in my computer was still working (and yes it was) even without the one pin. But the card was garbage after. so just be super carefull pulling them in and out. Mine are perminantly in my cameras now, unless i upgrade to a new card, then that one takes over. and yes, definitely turn the camera off before opening the memory card compartment, same with battery, it forces the camera to do instant shut downs, which skips the cleaning process and such. I assume, probably not the best thing for the camera. interestingly Windows Vista recognizes the software inside the cameras. it also has it's own built in importing abilities which work quite nicely. lightroom can also pull straight off of the camera too. I only find this technique only marginally slower, but at the same time, you're saving time by not having to open up camera, pull card, insert card elsewhere, then remove card, put back in camera, format. with camera, leave cord attached to computer, just plug into camera, and sit down, then do normal imporing procedures, then when done, unplug camera. what it lacks in speed read/write, it makes up for in time wasted moving a to b. So I've found anyhow. SD card, i wouldn't hesitate to remove and put into computer every time, just so easy... nothing really to go wrong like all those pins on the compact flashes. |
01-13-2012, 10:43 PM | #971 | |
Rep 7,457
01-13-2012, 11:25 PM | #972 |
no longer a BMW owner
154
Rep 1,463
i mean no disrespect here, but that 'don't pull your CF card' thing is a load of bunk. if you invest in a good card reader and good cards and you're careful, you pretty much rule out MOST chances of some failure. there will always be freak accidents like that...but if i'm out shooting a lot in one day and i don't have access to a computer, i don't hesitate to change cards. weddings, for example, might require that. i now use a 32GB card in my 5Dii, but i'd personally be far more concerned about a card corrupting than i would be about a pin problem. i can almost guarantee most pros don't just leave their cards in their cameras...they swap cards and keep shooting. and the average pro is going to swap cards more times in a month than a consumer will in a year or two.
01-13-2012, 11:59 PM | #973 |
Rep 5,114
sorry for exaggerating the point to the extent that you found it hard to swallow.
I'll try not to use the word "never" in such a strong way again. either way, if you're switching out a compact flash card while shooting a wedding, you either chose way too small a card to start, or you're shooting way more then is necessary. Lets say you shoot about 500 shots, that's between about 11 and 13gigs. you don't need a card that big. If you're shooting that much to need to swap out, I hope it's a monstrous wedding. I also don't really worry about switching out my cards that much as I carry 2 cameras on me, so it's not too often i find myself in a situation where i'll need to worry about switching out. And in Marks case, he probably doesn't transfer more then about 100 files at a time, so for any difference in time of transferring between camera vs card reader, there's really no point in being concerned about it. |
01-14-2012, 09:32 AM | #974 |
Rep 6,798
Reed, I understand your reservations with swapping out memory cards, based on your own personal experiences. However, I'd have to agree with Josh on this one. I've probably swapped memory cards in and out of my 20D over a hundred times with no problems whatsoever. Of course a freak accident like that can happen, but it's rare. As long as the track for the slot is long enough before it hits the pins, you should be safe. On the cameras it's good, on the card readers it may not be.
I have this card reader and it works great: Lexar® Professional USB 3.0 Dual-Slot Reader I also have a CF card reader for my iPad 2, and its slot is very short, so I have to be extra careful when inserting/removing the CF card from it.
01-14-2012, 09:54 AM | #975 |
154
Rep 1,463
i certainly don't mean to be condescending, just a bit incredulous based on my experiences. i can certainly see how using a cheap card reader could cause problems. i use a moshi reader that supports UDMA. it's fast, and i get a good seat every time.
01-14-2012, 10:08 AM | #976 |
Rep 5,114
don't worry guys, as i mentioned, I chose my words poorly, i shouldn't have said "never" it was an incorrect statement by me.
my point was is that the cards are more delicate then the SD card because of the pin system. And yes, there's a lot of shit readers out there. It took me 4 different readers just to get the information off my wrecked card before i was successful. |
01-15-2012, 02:31 PM | #977 |
Rep 1,550
More loitering around Millennium Park. I love the structure of and around the pavilion.
Should've used a slightly higher ISO and shorter shutter speed on this one....it's a little blown out on some of the metal panels of the pavilion. I love this angle w/ the arches, though.
- Jeff
bosstones' flickr |
01-15-2012, 04:28 PM | #978 |
Rep 7,457
Nice shots, Jeff.
01-15-2012, 04:45 PM | #979 |
Rep 1,550
Thanks, Mark! Too bad this week's contest isn't 'Dusk'. I was going to enter one of these but they don't really qualify as twilight. I found parking downtown a little too late. lol
- Jeff
bosstones' flickr |
01-16-2012, 08:51 AM | #980 |
Rep 4,856
Can someone post some before and after Night photos? I want to see how the photo look like from the beginning haha.
Does Photoshop CS3 support RAW images? Last edited by Prissy; 01-16-2012 at 09:45 AM.. |
01-16-2012, 09:19 PM | #981 |
I wanna go fast!
14
Rep 343
Drives: like a madman.
Yes, CS3 does support camera RAW files, just not for your camera. It's too new. Lightroom 3 and CS5 support it, if you get the Camera Raw 6.5 plug-in update.
01-16-2012, 11:32 PM | #982 | |
Rep 1,550
CS3 will natively support raw from some of the older gen dSLRs (I know it works directly for my XTi). For newer ones, there's DNG Converter off Adobe's website that'll convert the native camera raw to something PS can/will work with. I use DNG Converter for 5D raw files...haven't tried G12 raw files yet but I assume the utility will be needed as well.
- Jeff
bosstones' flickr |
01-17-2012, 09:23 AM | #983 | |
Rep 4,856
01-17-2012, 09:25 AM | #984 | |
Rep 4,856
DNG converter = free? |
01-17-2012, 09:38 AM | #985 |
Rep 7,389
They'll have the plug-in probably within 60-days. Until then you'll have to use the software provided by Sony. Save to DNG and then process further in PS.
01-17-2012, 08:44 PM | #987 | |
Rep 1,550
- Jeff
bosstones' flickr |
01-17-2012, 08:55 PM | #988 |
Rep 3,102
Drives: Happy on H&R coil overs
awesome shots Jeff and welcome back
2008 E92 335xi ------->Links to my Mods: H&R Street Performance Coil Overs || 19" Alufelgen CS7 || Interior Swap: Black to Coral Red
My Website || My Flickr || My Tumblr || My Twitter|| My Facebook|| My 500px |
01-17-2012, 08:56 PM | #989 |
Rep 3,102
01-17-2012, 09:05 PM | #990 |
Rep 7,457
Very cool picture, Tim. Esplanade?
