2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes ACS vs H&R springs
      04-01-2017, 01:31 PM   #89
Mackie02
Drives: 2014 550i M-Sport
Originally Posted by 007F10 View Post
the spring battle continues lol....
My good friend had a f10 550 with H&R and didn't like the bounce so I went with ACS ( I know diff models are affected differently)
I have the ACS springs and a GF that doesn't like lowered cars so I can comment on that.
I can tell you from my experience (13' 535i msport), the ACS springs are perfect for me and the GF hasn't complained once. Right after instillation I was concerned with the height cause it didn't drop much but after a month or so it settled in just perfect. Like others have said the MSports should come from the factory with these springs. Height is perfect, ride is GREATLY improved, and no bounce. No matter the spring you run I think it looks much better on 20's as well, and I have some Fatty tires (255F/295R) but that is just IMO. Also if you run the right wheel even OEM you don't need spacers, I'm running the 303m wheel from the 7ser and the offset is perfect. (attached Pics)
I am still on stock struts and ride is fine but I understand the risk of having to replace down the road
**Note I need to take some new pics since the tire change, here is a pic with the 7 spec wheel. my new tires are much more square and fill that little gap left on the offset
What tire setup are you running?
      04-07-2017, 11:50 AM   #90
andy_sk
Drives: 535i Euro Spec M-Sport
Originally Posted by thelowkick View Post
I am on H&R and I don't really have a problem with the ride quality at all
That is a BEAUTY!!
007F1063.00
      04-12-2017, 06:41 PM   #91
007F10
007F10's Avatar
63
Drives: 13' 535i Msport AW
Sorry didn't get the notification of the post.
I am running 255/35/20 and 295/30/20 Kumho ESTA PS91
Couldn't be happier, aggressive tire, no rubbing. Two big thumbs up
2013 535i Msport
RIP: '95 E36 M3 | '90 E30 325is | '87 E30 318i
      04-20-2017, 10:13 PM   #92
STR8-6IX
Drives: RWD 528i N52
Originally Posted by Bmw2012 View Post
I own a 2012 535i and i will like to get some advise from you all, which springs should i install on my ride?
Don't get lowering springs not good for your factory struts. ACS springs are better then H&R. I would get bilstein sport struts or koni with ACS
      04-20-2017, 11:43 PM   #93
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Don't sleep get the koni adjustables. I adjust mine every so often when I get tired of a certain firmness
IG: @bmwdoubles
      04-21-2017, 10:39 AM   #94
STR8-6IX
Koni and Bilstein are both great. the bilstein is more sporty while the konis have a more forgiving ride, but I am not sure if the bilsteins are adjustable. they will probably last in the long run better then the konis though which is another thing to consider.
ultimately, if you live in an area with rough roads the konis may be a better option. otherwise, get the bilsteins.
      04-21-2017, 03:26 PM   #95
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
The koni's cranked all the way up are too stiff for daily driving. that said they can make our F10 boats somewhat track competent. Street for me is 1 full turn in the front and 1/2 turn in the rear. For family trips I set them to full soft and no one in the car complains.
IG: @bmwdoubles
      04-21-2017, 03:29 PM   #96
STR8-6IX
lol.
but which springs are you using on the konis? ACS or eibach will be better paired to koni/bilstein and more forgiving.
