2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions M5 Diffuser Install with Comfort Access F10's
      09-16-2017, 09:40 AM   #89
bk_mike
Drives: F10 550ix
Originally Posted by AldoNY View Post
I'm in the same boat. I want to fit the diffuser on first before i out on my m5 exhaust. Dis the diffuser fit with the original exhaust from the 550i traps?
The M5 diffuser will not fit with the factory 550 tips. You can cut them off and adjust the muffler a bit if you need to fit the diffuser first and then fit the mufflers.
      10-23-2017, 10:36 PM   #90
dreilly36
Drives: 2014 535d Xdrive M Sport
Did you paint your diffuser or did it come that color?
Originally Posted by Highpriest0303 View Post
I just did this conversion from a regular Msport Diffuser to M5 Diffuser. Thank you for the DIY guides. It took me 2 hours at least but it is well worth it. I replaced the adapter and the CA (Comfort Access) is working like a charm.
I have an appointment next week to install my M5 Quad muffler so i am excited and hoping that the muffler install doesn't get too complicated.
Also today my Cyba 90MM Dark Black Quad Tips arrived and they look nice!
Here is a picture of the M5 Diffuser without the Quad yet
If anyone located on the Island need my help with this conversion, just hit me up and i don't mind helping out as long as you bring some beer for refresher
      11-28-2017, 08:59 AM   #91
Nova1800
f10 lover
Switzerland
Drives: Bmw 550i
why i cant see images in the forum
I have message who say update your profil to allow 3rd part .... what i need to do? thank you
      11-28-2017, 08:15 PM   #92
antaholics
Drives: 2012 535xi M-Sport
I ordered one of the eBay carbon diffusers ("v-style"). Does anyone have experience with getting comfort access to work with that?
The seller told me that it won't work because the CF blocks the signal, but something tells me someone has made some mods for it to work. I'm sure I'm not the only one in this boat!
Thanks in advance!
      01-19-2018, 11:31 AM   #93
Black Ghost
Drives: F10 LCI
Selling brand new M5 Diffuser for F10 + Vorsteiner Exhaust
The diffuser is brand new in the box.
The exhaust is used and does not have the Y pipe but I have the mufflers and rest of piping.
Also for sale are barely used H&R lowering springs.
DM for details.
      12-15-2018, 12:21 PM   #94
bossjnk
Drives: 2015 BMW 535i MSport
Did you figure this out? I’m trying to do the same conversion.
Thanks in advance!
Did you get comfort access to work with eBay CF diffuser? Do I need to get M5 insert piece or this absorber https://www.getbmwparts.com/oem-part...er-51128053585
Still a bit confused since this thread is talking about specifically M5 oem diffuser and I’m looking for Aftermarket CF. Please help me out here.
      04-10-2019, 04:42 PM   #95
Duckysaurus
Duckysaurus's Avatar
42
Drives: 2021 G05, 2014 F10, 2009 E90
2014 BMW 535xi  [8.50]
2009 BMW 328i  [0.00]
Just a note: the 3 bolts/screws under each rear wheel fender are really annoying to reach, you'd have to take off both rear wheels to reach them unless you have a flexible ratchet wrench. Tried today and that was the part that got me stuck. =/
      04-20-2019, 08:16 AM   #96
Jamrockbwoy
Drives: 2015 550i xDrive
I finally got a chance to get this Quad upgrade done today. Shout out to Richie @ United Exhaust Shop in Ronkonkoma, NY who got it done very effortless.
The two hangers from the M5 muffler (front/back) are perfectly aligned with the M5 Diffuser. There are no modification done on both hangers. They fabricated a 10 inches pipe to marry the 2.5 and 3.0 pipe (535 size pipe and M5 Size pipe) and aligned the muffler.
They also managed to installed my Black Chrome 3.5 Cyba Quad tips and aligned that too.
Here are some of the Pictures, not the best shot but all i got
I got more pics of the whole process should anyone wanted to see them just PM me.
The initial start up sounds definitely added a nice growl to it and did not notice any drone on a normal highway driving at all.
The shop suggested if i need more sounds is to delete the resonator and do a straight pipe which will most likely be my next mod.
I also used a stainless steel hose clamps to hold the valve open if anyone curious whether i left it close or open.
Any question, please let me know.
Thank you all!
I know this is really old but do you remember how much they charged you to do this work?
Instagram @_gr8dane
2015 550xi - current
2015 428xi - retired
2010 328xi LCI retired
      06-28-2020, 12:45 AM   #97
gr8brwnshark
Drives: 2013 BMW 528i, 2006 BMW X5
2013 BMW  [0.00]
Bringing back this old post since I've recently just installed an M5 diffuser on my 2013 528i w/ M-Sport Package WITHOUT COMFORT ACCESS and there were some questions that were still unanswered for me before I installed it. To answer one question many have asked, the removal of the bumper will likely still be necessary even if you do not have comfort access. I didn't have comfort access however I did have to remove my bumper and replace the old adapter with the M5 adapter. In regards to the prior posts regarding removal of the bumper, it is true that only 4 screws needed to be removed: 3 under the wheel well, and one located underneath the drip trim panel on the taillight. I was fearful of removing the bumper however I was able to do it after some time, with the help of someone else and with enough force pulling back. Once that was done, I was able to get into the adapter that needed to be replaced. IMPORTANT TIP: you can use a trim removing tool, one that's headed with a thick triangle to remove the series of tabs on the old adapter. I didn't know this prior and broke one of the tabs trying to pull it out, if you have the right tool, you can insert it into each of the tabs to snap them free from the metal part of the bumper. After removing the adapter, I was able to easily snap in the new M5 adapter. Since I don't have CA, all I needed to do was fit the TPMS sensor and mounted this behind the adapter in a small slot with some double sided tape. Snapped the bumper back into place, screwed it in, and then was able to smoothly install my M5 diffuser. I have my quad Remus Exhaust ready to be installed sometime this week and I couldn't be more excited!
      08-30-2020, 07:49 PM   #98
Christoefur
Drives: 2014 BMW 535d
I know this is an old post but I was wondering if someone can give me some insight. I just replaced the diffuser, only issue is now the comfort access isnt working. Is comfort access the strip tacked down by those push in pins? If its somewhat loose (some of the push in pins broke), could that be the culprit?
      10-07-2021, 06:41 PM   #99
Sasha85
Drives: BMW 535i
Alan, you had a fantastic post on how to add an M5 diffuser to an M-sport F10.
I have a follow up question on this topic (sorry, I know it's been covered in various degrees).
If I remove the 535i M-sport rear bumper Absorber and replace it with the M5 Absorber, will I be able to apply a Carbon Fiber M5 diffuser from brands like RKP or 3D Design? It seems clear by your post the OEM M5 diffuser would work no problem.
      03-20-2022, 06:53 AM   #100
slobo7x
Drives: 2016 550 F10
The original link for the web site to order the diffuser and insert together is not working..
I wonder if you need:
Diffuser----- 51128050480
Adapter------51128053585
Insert--------51128038985
or just Diffuser and adapter for comfort access? 2014 535 M sport here with comfort access.
Thanks!
      03-20-2022, 09:21 AM   #101
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Thanks!
Need insert too.
      03-20-2022, 09:24 AM   #102
slobo7x
Thanks!
Need insert too.
      03-22-2022, 03:31 AM   #103
Krainis
Lithuania
Drives: E30 327i, E87 120i, F11 530D
Originally Posted by shoek View Post
Great guide Alan and Jz!
Does anyone know if you can order an OEM or non-OEM M5 diffuser that is already finished? I want one that matches my 550's M-sport diffuser color (grey/black).
I think it's B27 color.
      07-21-2023, 06:00 PM   #104
n3985
Drives: a car
Sorry to bump an old thread!
I am in process of installing a 3D Design diffuser which was meant for an M5 on my factory M Sport rear bumper.
If I do nothing to do the Comfort Access module and antennas and TPMS module i.e. leave all it alone, will most aftermarket diffuser clear the non-M5 adapter to reinstall? I think yes except then CA signal will be blocked?
Thanks!
Edit: reading more it looks like the original adapter will not fit due to modules blocking the M5 style diffusers.
Edit 2: wanted to confirm with M5 adapter + aftermarket M5 diffuser, it all went back on easily and Comfort Access works like before. Like others I installed both top and bottom CA antenna into the M5 adapter then taped both the TPMS and CA module behind the metal crash bar.
My car is a 528xi with factory M Sport + 3D Design diffuser meant for M5 painted black. Note for any N20 owners you’ll need to notch the diffuser due to width of factory muffler (see pic with blue tape).
