2010 2011 BMW 5 Series Forum F10 Post your favorite pic of your car |
03-27-2021, 11:17 PM | #1147 | |
Rep 2,595
I'm about to swap out my Silvers for KWv3's, which is why I held off on it. Not sure how it'll sit on the KW's yet.
2015 BMW 535xi
Dtex535101.00 |
03-28-2021, 06:11 PM | #1148 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
I have 10mm spacer upfront with my 343m wheels and KWV3. Saw the same setup on a fellow local forum member and that sold me. At the car's current height, 8mm would have been better, but they don't come hub centric and I won't lower the car more just to get the wheels to sit in a bit (love my front lip more).
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) Last edited by spielnicht; 03-29-2021 at 09:44 AM.. |
Unspec1311.50 |
03-28-2021, 09:48 PM | #1149 | |
Rep 192
03-29-2021, 09:47 AM | #1150 |
Petrolhead
445
Rep 814
I always feel like these pics are highly subjective because it's all about the angle, but here you go.
I can take more in the light after work.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
03-29-2021, 11:04 AM | #1151 |
Rep 192
03-29-2021, 11:37 AM | #1152 |
Rep 1,156
Thank you!
From Friday morning at 7am. Love NorCal Spring Mornings... |
03-29-2021, 12:46 PM | #1153 | |
Rep 2,595
I agree that 8mm would have been slightly more ideal. Have you thought about getting hub extenders so you can run non-hubbed spacers?
2015 BMW 535xi
OnlyGerman363.50 |
03-29-2021, 12:48 PM | #1154 |
Petrolhead
445
Rep 814
Yeah on V3s. I have it right in the middle of KW's recommended height setting. Like I said, if yours is lower, the 10mm spacers would be 100% perfect. I feel like my front wheels can sit in 1-2mm, at least to my liking.
Dtex535101.00 |
03-29-2021, 12:59 PM | #1155 |
Petrolhead
445
Rep 814
I'm running 245/285 combo. I haven't honestly thought hub extenders. I'd definitely be open to them if I can get smaller spacers. I'll do some research. Thank you!
Dtex535101.00 |
03-29-2021, 01:20 PM | #1156 | |
Rep 2,595
https://f10.5post.com/forums/showthread.php?t=837326
2015 BMW 535xi
spielnicht444.50 |
03-30-2021, 12:04 AM | #1157 |
Rep 2,595
On a bit of an unrelated note, could you take more pictures of how the 245/35/20 sits on the front rims? I want to go down to 285 on the rears instead of the 295's I already have (tires poke a bit due to the thicc) but I've been unsure of how the 245's will look on a 9" rim. Worried it'll look stretched. Thanks!
2015 BMW 535xi
03-30-2021, 09:33 AM | #1158 | |
Petrolhead
445
Rep 814
Here you go from different angles.
Unspec1311.50 |
03-30-2021, 11:45 AM | #1159 |
Rep 192
03-30-2021, 11:54 AM | #1160 |
Rep 965
03-30-2021, 03:40 PM | #1161 |
Rep 2,595
Awesome, thanks! One last thing sorry haha. Do you mind posting a picture of how the 285 looks in relation to flushness with the fender? I'd hate to downsize only to realize that it still pokes a bit. Appreciate it.
I am quite curious as well. I will also being doing a full suspension bushing re-indexing once the V3's coilovers are settled in
2015 BMW 535xi
03-30-2021, 04:04 PM | #1162 | |
Rep 965
I run 285/30/20 in the back. 20x10 M5 343 wheels. They poke much more with Michelin A/S 3+. I had to raise the car 1/4 inch. Was more flush with Hankook Evo2's. |
03-30-2021, 07:53 PM | #1163 | |
Rep 2,595
Example: https://www.realoem.com/bmw/enUS/sho...diagId=33_1453 Bushings in #4, #10, #12, and #17 need to be re-indexed. https://www.realoem.com/bmw/enUS/sho...diagId=31_0863 Bushings in #1 and #6 need to be re-indexed. I plan on writing a guide on how and which bushings you need to re-index, along with including an excel spreadsheet detailing which bolts must be replaced and which are only suggest by BMW. Ball joints aren't affected by this.
2015 BMW 535xi
Sylverlee150.00 |
03-31-2021, 01:54 PM | #1164 |
Petrolhead
445
Rep 814
It's pouring outside today. I'll get you closeup of the fender tomorrow hopefully.
Unspec1311.50 |
04-01-2021, 07:12 PM | #1165 |
Petrolhead
445
Rep 814
Here you go. No way around it if you have M5 wheels (or similar specs), they're gonna stick out a bit on the rears. At my current height settings though, I've had zero rubbing even with 4 passengers.
04-02-2021, 11:24 AM | #1166 |
Rep 51
South dakota trip
cdmulders330.50 ezaircon4jc4557.50 |
