2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
04-20-2019, 12:36 PM | #111 |
Rep 17
Bozman52 Thanks for that info. I figured the rear E60 M5 parts would't fit, but from what I read in this thread, the fronts should work, unless I misunderstood something. Now for the rear brakes, a few people stated using the rear F10 550i calipers and rotors, but I'm still unsure whether its EU or U.S. specs.
04-20-2019, 12:54 PM | #112 | |
Rep 112
Regarding the rear 550i setup, I thought the US and Europe specs were the same. I just pulled up both versions on RealOEM and confirmed this is the case; they both use the same part numbers for the rear. Here is what you need for the 550i rear brakes: Rear Rotor (345x24)- 34216775289 Rear Caliper- 34216793047 and 34216793048 Rear Caliper Carrier- 34216793053 and 34216793054 Rear Pads- 34216775346 |
04-23-2019, 08:09 PM | #114 |
Rep 951
Sorry for the late response on this.. But no the F01 did NOT come with the blue paint. However, the B6s did come with the blue paint. That's where I got the idea.
04-23-2019, 08:16 PM | #115 | |
Rep 951
BimmerOwner46.50 |
04-24-2019, 03:13 PM | #116 | |
Rep 342
I actually bought a stoptech BBK for my car after I got the 760 calipers and pads but I am looking to sell them to someone and want to make sure I communicate the correct rotors required to complete the upgrade. |
04-25-2019, 05:56 AM | #117 | |
Rep 112
Front Rotors: 34116789543 and 34116789544 Front Calipers: 34116786827 and 34116786828 Front Caliper Carrier: 34116786829 Front Pads: 34116794464 The caliper carrier is the only part that is the same between the 550i/750i and 760i/Alpina B7 front brakes. |
T-Bone1822.00 |
04-27-2019, 09:02 AM | #118 | |
Rep 342
04-29-2019, 10:27 PM | #119 |
Rep 118
Here's a question...If I were to upgrade the fronts and rears on my US based 535d to the 760 fronts and 550/335i rears (both larger rotors and calipers), should I also upgrade the master cylinder to the 550 version at the same time? Would I need to consider any other factors?
Thanks for the input! |
04-30-2019, 01:47 AM | #120 |
Rep 112
You will not need to upgrade your master cylinder with the 760/550 brake upgrade. DARKKNIGHT put 4-piston X5M calipers on his F10 and did not upgrade the master cylinder. My understanding is that if you go for the full M5 brake retrofit, which is not a simple bolt on mod, then you'll have to upgrade the master cylinder.
05-17-2019, 06:18 AM | #121 |
Rep 112
DARKKN1GHT, I'm wondering if you still have any of those spacers sitting around for the X5M front calipers that I could buy off you. I also sent a PM, but didn't hear back, so thought I'd try to ping you here as well.
06-01-2019, 10:15 AM | #122 |
Rep 99
Drives: 2015 550i
What if i just wanted to have drill slotted rotors? would there be any issues with using aftermarket drill slotted rotors and oem calipers for 550i?
06-01-2019, 07:22 PM | #123 |
Rep 292
Copied
New project - retrofitting the F10 550i front rotors into a 535i ..... This interesting topic popped up previously in various forums around the world. And today we had the opportunity to implement this project here in Singapore. Stopping efficiency is dependent on a couple of factors - Friction coefficient of the brake pads - Tyre traction - Force of the caliper clamp - Size of the rotors This upgrade of rotor size using a larger rotor from the 535i's brethren would provide increased stopping power. The general rule of thumb is that the larger the rotor diameter, the more torque is available to slow down a rim. It's like lengthening a lever from its pivot point .... The stock F10 535i rotor measures 348 x 36. The F10 550i on the other hand measures 374 x 36. The upgrade would also include the larger brake dust shields and a set of brackets to hold the calipers together ...... The zinc coating would provide protection against rust and corrosion. The larger bell housing helps reduce the rotational mass. We paired the rotors with a set of Porterfields R4-S which has a higher friction coefficient then the stock pads due to its Kevlar and Carbon content. You may be surprised but the one thing that would influence brake fade is the brake fluid. We know we have to test it at every servicing but to bleed it correctly is a matter of process or experience - this we will talk more about in the next post |
06-02-2019, 09:03 AM | #124 | |
B1990BB
Rep 43
I assume direct fitment either F01 or 550i preferred? buy new or used preferred for the calipers? edited: dumb question sorry! so I assume as my n20 520i is a slow ride but I want a better brake performance, I would have to buy all of these? and just plug and play to it??? Front Rotors: 34116789543 and 34116789544 Front Calipers: 34116786827 and 34116786828 Front Caliper Carrier: 34116786829 Front Pads: 34116794464 correct me if I am wrong please, as if all good I am going to start hunting!!
06-03-2019, 03:53 PM | #125 |
Rep 54
06-03-2019, 04:17 PM | #126 |
Rep 292
06-18-2019, 03:16 PM | #127 |
Rep 140
E60 M5 calipers bolt directly onto f01 376mm rotors.
https://f10.5post.com/forums/showthr...6#post24927566 Last edited by _des_; 06-18-2019 at 05:15 PM.. |
06-25-2019, 04:14 PM | #128 |
Rep 1
Hi all,
I recently did the upgrade from the first page (items below) and thought I'd give some feedback. Thanks to .BMW. for the original research. I got the calipers with carriers from the US off a 750i F01 and bought new discs. The purpose the car is used for involves lots of frequent hard braking with quite a bit of weight in the boot. The stock brakes always felt like they were on the limit and would start fading after 5 or 6 hard applications. This new setup doesn't grab like the stock ones did in slow moving traffic and which is especially noticeable when auto-brake is enabled. I've not noticed any fade whatsoever during hard use and there's also less dust (bonus!). 2k miles and all good so far Steve 550i in Europe instead uses 2-piece directional 374x36 rotors. L: partnr. 34 11 6 785 675 R: partnr. 34 11 6 785 676 Caliper housing. L: partnr. 34 11 6 786 817 R: partnr. 34 11 6 786 818 Caliper carrier. Partnr. 34 11 6 786 829 Brake pads. Partnr. 34 11 6 851 269 |
jayster0966209.00 |
06-30-2019, 09:31 PM | #130 |
Rep 951
Wanted to revive this thread regarding rear brakes. I am looking to use the 370x24 size rotors for rears but trying to figure out if the stock calipers will handle these. Any ideas?
07-04-2019, 10:11 AM | #131 |
B1990BB
Rep 43
update, I decided to go ahead and just purchased the APracing calipers and then used the brembo disc rotor 380mm on it and as I have also bough the f01 parts, just a thought can I install it to my rear instead of my front and still have my ebrake functioning?
07-06-2019, 09:48 AM | #132 | |
Rep 112
These guys are out of California and take solid OEM replacement rotors (can't recall the supplier, but I recognized the name) and slot/drill them. As I live in the UK, it ends up being cost prohibitive for me to buy from them due to import fees, but I did spend about 20 minutes on the phone chatting with a guy from Brakenetic. It seems like a pretty legit operation, but I obviously have no direct experience with them other than a conversation. The guy I spoke with was really knowledgeable, though. Over here in Europe, I've found cross-drilled rotors right out of the box from a company called Zimmerman, so that's what I'll be buying when I finally pull the trigger on all this brake upgrade stuff. |
