2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Drivetrain Malfunction
      09-17-2016, 01:55 PM   #111
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
I received the dreaded Drive train malfunction on my 2014 535d with 27k on it. After running the fault code, I discovered it's the EGR valve. Has anyone with a 535d experienced this? The fault code went off, and hasn't returned. Thank god I have a full warranty until 2020. I guess I'll take it to the stealership on Friday and see what is up.......
      09-17-2016, 06:17 PM   #112
SchillerM
Drives: 11' 550i, '00 M5, '11 E90 335i
Originally Posted by SchillerM View Post
Had this happen on way home yesterday, rough idle and no power. Malfunction pops up almost immediately on start up. UGGG
Misfire Cylinder #2... Rheingold returned "Measurement Invalid" on Cyl #2 and #8. Heading to dealer on Monday
Just over a month with the car, luckily aftermarket warranty kicks in at a month... Knew it was possible, but THIS SUCKS so soon after getting car...
Took car in on Monday, got it back Friday. Cyl #2 injector and plug replaced, also had the blower motor replaced due to foam filter coming apart and making it out of balance, was LOUD when running at high speed, whisper quiet now.
$2300 in repairs, $60 out of pocket for replacement filter.. 2/3 of warranty recouped, 35 months left...
Matt
2011 Space Grey 550i - Eisenmann exhaust, ACS Springs, Dinan Intercoolers, Intake, & Stage 5 tune
2011 Space Grey 335i - M Performance exhaust - Wifes
Past: 2000 Avus Blue M5 - Dinan exhaust, flywheel, & tune 180k+miles
      01-31-2018, 05:30 PM   #113
Bossman535
Drives: Alpine white
Originally Posted by Pleather View Post
Just got the same message on my 550. I turned it off and on a few times and it kept coming back. Several times it wouldn't go into gear until I recycled it. Going to dealer tomorrow.
How did u recycle it ?
      11-11-2020, 06:00 PM   #114
5seriesGordon
5seriesGordon's Avatar
Drives: BMW 528i
How did you recycle it?
      11-22-2020, 04:15 PM   #115
pakiplaya1
Drives: '11 535i - Alpine White
Originally Posted by LORENANN View Post
We had this message almost immediately, returned car to the dealer, took them a half hour to find the problem. A short, 3 inch or so, flexible tube connected to the turbo would kink and after replacing it it has never recurred.
Could you elborate? i am having the same issue with my car when i hit the gas and it goes to downshift.
      11-30-2020, 12:59 PM   #116
thebutlers96
Drives: 2012 528ix
I have been having this problem when the auto start function activates. Today was the worst- I came to a stop, the car turned off and the drivetrain malfunction in red came on (usually it's in yellow). Then the car wouldn't start as though the battery was dead. Then I tried to start the car again and all it did was turn over without starting. I took my finger off the starter button but the car continued to try and start. This happened 3 times. Car started normally on the fourth try and the error message was gone. Going to the dealer tomorrow
      02-04-2021, 12:16 PM   #117
thatbasef10
thatbasef10's Avatar
Drives: 2016 528i xDrive
I just got the message for the first time after 90,000 kms (56,000 miles) and it was just before I got an oil change. After looking up it shows that it could just be something that was knocked loose. Any ideas?
