2010 2011 BMW 5 Series Forum F10 F10 M5 Brakes on 528/535/550 ??? |
10-06-2015, 09:43 AM | #112 | |
Rep 14,521
10-06-2015, 09:44 AM | #113 |
Rep 14,521
10-06-2015, 10:49 AM | #114 |
Rep 14
Drives: F11 M-Sport
Would I need the custom brackets if I can get the full OE M5 carrier/hub set up?
10-21-2015, 12:21 AM | #115 |
B1990BB
Rep 43
+1 for this,
so for big brake kits whats the best option for a non M cars, with the appropriate budget? I heard there are r1concept BBK, Ksport BBK and so much more in the market.
01-16-2016, 03:51 AM | #117 |
Rep 14,521
01-25-2016, 05:10 PM | #118 |
Rep 1,084
Drives: 2013 BMW F10 550 Xdrive Msport
You know me, I am up for ANY mod... lol So, we need the M5 Caliper, the M5 400mm rotor, M5 brake pads, brake lines and the bracket made in Russia? Is there any cutting involved anywhere?
01-26-2016, 03:36 AM | #119 |
B1990BB
Rep 43
it seems a long way to go.
to m5 brakes seems like we need a custom bracket like stated its not going to be cheap that is indeed.
01-26-2016, 08:42 AM | #121 |
Rep 1,084
Parts list for M5 Brakes onto Standard F10 (Front)
Still putting together Rear part numbers. Left Caliper 34117845747 $767.66 Right Caliper 34117845748 $767.66 Left Rotor 34112284101 $394.57 Right Rotor 34112284102 $394.57 Pads set 34112284869 $346.10 Brake hoses 34322284318 $51.68 each (2 needed, one per side) Custom Caliper Mount |
01-26-2016, 09:38 AM | #122 | |
Rep 14,521
01-26-2016, 09:39 AM | #123 | |
Rep 14,521
01-26-2016, 09:41 AM | #124 |
Rep 14,521
i did look into the CEIKA's and tho price isn't too bad a lot of mixed reviews
01-27-2016, 12:21 PM | #125 | |
Rep 39
additional parts needed other than calipers and rotors. Someone please correct me if I'm wrong. Thanks |
01-27-2016, 12:42 PM | #126 | |
Rep 14,521
01-27-2016, 12:58 PM | #127 | ||
Rep 39
Thanks! (No. 7 in the diagram is the carrier) |
01-27-2016, 03:18 PM | #128 |
Rep 1,084
My research has shown:
All parts available from www.getbmwparts.com Ask for Jason Front Brakes: Left Caliper 34117845747 Right Caliper 34117845748 Left Rotor 34112284101 Right Rotor 34112284102 Pads set 34112284869 Brake hoses 34322284318 each (2 needed, one per side) Custom Caliper Bracket Rear: Rear caliper left 34217845815 Rear caliper right 34217845816 Rear pads set 34212284389 Rear brake lines 34322284319 each x 2 Left Rotor 34212284103 Right Rotor 34212284104 Rear Custom Caliper Mount MUST have at least 20 inch rims for Rotor clearance... Install, bleed and drive. HIGHLY suggested you do front and back at same time to eliminate issues with ABS. Now, the only thing to consider is the Electronic Parking brake on the rear, which I need to find out is adaptable to new M5 Rotors and Calipers. https://www.drive2.ru/l/5698330/ https://www.drive2.ru/o/b/2498650/ Will post pics of adapters once they arrive and will build a DIY document on the install. Last edited by mikekilpatrick; 01-28-2016 at 10:16 PM.. |
01-27-2016, 05:15 PM | #129 | |
Rep 1,084
01-28-2016, 06:26 AM | #130 |
Rep 26
See some update on this M5 brake upgrade development:
http://forums.racingbrake.com/showpo...92&postcount=7 Last edited by WarrenRB; 01-28-2016 at 06:27 AM.. Reason: duplicate posting |
01-28-2016, 09:10 AM | #131 |
Rep 124
This is the bracket you need.
Made of aluminum alloy, precisely designed and machined here in Solcal, USA Brackets may be made available for separate purchase (depending on how many people are interested.) Multi-sourcing retrofitting may work and appear have some money saving advantage but is not always the best, for example M5's 400x36 rotor & pad size can be overwhelming for 5 besides you should also consider future maintenance/replacement, you must replace the whole rotor assembly and the brake pad is not cheap either. We are preparing to offer a complete brake kit properly designed with our light weight two piece rotors, the rotor replacement ring is cheaper, so is the brake pad (standard FMSI) Last edited by racingbrake; 01-28-2016 at 09:25 AM.. |
01-28-2016, 10:42 AM | #132 |
Rep 14,521
