2010 2011 BMW 5 Series Forum F10 Anyone mounted original M5 343M 20" rims on an F10/F11 |
12-02-2016, 06:28 PM | #133 |
Rep 133
I just went through the same thought process. First for tires 245/285 is what you'll want because a 295 will rub. Next fitment, 2014 models need a spacer. Some have used a 3mm or 5mm without issues but you run the risk of vibrations at high speed because the wheel is no longer contacting the hub much if at all (i.e. no longer hubcentric). A 10mm is the smallest spacer with a hub on it to prevent the issue, but you may poke out a bit up front. I decided against it on my 2014, but would love to see how it looks on yours if you get them set up.
Just a squirrel trying to get a nut
12-03-2016, 05:59 AM | #134 |
Rep 429
Could the fronts from the M6 be used, and rears from an M5? Then spacers wouldn't be needed for the front.
I believe they're 20x9.5 31 offset. Or, maybe they won't be flush? |
12-03-2016, 08:55 AM | #135 |
Rep 29,203
But then you only have 0.5" stagger between the front and rear wheels.
12-03-2016, 08:57 AM | #136 | |
Rep 429
12-03-2016, 05:19 PM | #137 | |
24FITcoach
32
Rep 76
Can't find one. I don't want the wheels to stick out of the car |
12-03-2016, 05:20 PM | #138 | ||
Rep 133
12-03-2016, 06:57 PM | #140 |
Rep 133
Yeah, pre-facelift is great, they just mount right up and look amazing. Nice set there.
07-21-2017, 07:48 PM | #142 |
Rep 30
20" M5 343M rims on 2014 535i XDrive M Sport
I am running stock suspension with 255/35 Front and 285/30 Rear with zero problems. Rides great handles great.
http://www.bimmerfest.com/forums/sho....php?t=1021529
2014 BMW 535i X Drive M Sport
Carbon fiber Performance rear deck lid, Carbon Fiber Mirrors, Carbon fiber front bumper spoiler, M Performance exhaust and 20" M5 343M wheels with MPSS tires |
12-16-2017, 03:46 PM | #145 |
Rep 55
Hi, I recenty bought F11 M550d LCI, which share same front brakes as 550i. I have a chance to buy used 343M wheels, but I need to void using spacers upfront, since 3mm or 5mm are not hub centric and on top of that BMW wheels have beveld hubs, thus the risk for vibrations is high. I came to idea to buy used 550i pre-LCI front brake calipers and brackets. Do you think this are interchargable? Can someone get part numbers for this?
12-22-2017, 06:28 AM | #147 |
Rep 55
03-13-2019, 11:28 PM | #149 |
Rep 1
The oem m5 wheels will rub on the rear fenders with sumitomo tires 285/30/20 in rear. Haven't tried going with 275/30/20 but that might be the best bet. I have 255/35/20 upfront those are okay. I have a 2013 535i with the m package
03-14-2019, 03:42 PM | #150 |
Rep 346
Man your 343’s stick out a lot. Are those m6 343’s. Mine don’t stick out that much.
07-25-2019, 03:59 PM | #153 |
Rep 254
Has anyone ran 2 pairs of fronts in a square setup on an xdrive car? I know I could run 245/285 and be perfectly fine with staggered wheels but I'd rather be safe than sorry
08-07-2019, 09:32 AM | #154 |
Rep 1
What's been your experience?
Been following this thread recently. Looks like a lot of folks with the same thinking I have. But, for those who have applied it, I'm curious on your experience and results so far? I have a '14 550 Xdrive and I want to put 343's staggered with 245 fronts and 285 rears with a 5mm spacer in the front. If you've done this already, what's been your experience? Curious before I pull the trigger. Thanks.
