2010 2011 BMW 5 Series Forum F10 Anyone mounted original M5 343M 20" rims on an F10/F11 |
03-16-2021, 04:57 PM | #155 |
Rep 81
Bringing this back because I think I accidentally bought m6 343m wheels for my f10. Downsized the tires from 295 to 285 thinking this would've made it more flush but it still sticks out quite a bit. The car rides smoothly and I usually never have many people with me so rubbing isn't an issue. Is it safe to keep running this set up?
03-16-2021, 07:47 PM | #156 | |
Rep 2,595
2015 BMW 535xi
03-16-2021, 09:07 PM | #157 | ||
Rep 81
03-17-2021, 12:23 AM | #158 | |
Rep 2,595
There's really no reason you can't unmount the tires and mount them on M5's, the tires will fit fine. You'll just need to go through the hassle of selling your old wheels.
2015 BMW 535xi
11-26-2021, 02:31 PM | #159 |
Rep 71
I just bolted on OE 343M wheels to my 2011 550i MSport with stock suspension for a test fit.
Tires are 305/30/20 and 275/35/20. No need for spacers anywhere. There are about 5-6 mms to the front caliper from the rim center/hub. I don't see the caliper deflecting that much under load. I tried a few hard stops and no marks on the caliper or rim. I think the 343m rims are perfect for this car as is. The 305 tires seem like they *may* clear the fender if camber changes favorably under compression but I did not drive the car long enough with people in it to test. I see that some posters reported 295s rubbing but not sure about the F10 model (and if the hub spacing is different on a 550i compared to other models). I am planning to go with 295/30 and 265/35. I will have the rims finished back in OE machined silver first; don't like the all black look. UPDATE: I replaced the front hubs because the bearings were done and the front wheels rubbed slightly on the calipers. Either the new hubs were speced a bit differently(more likely) or whatever corrosion/dust was on the previous hubs acted as a spacer by 1-2 mm (I doubt it). So, I had to get 3mm spacers and they work fine.
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
EV8634.00 |
12-26-2021, 09:49 AM | #160 |
Rep 71
I had the wheels powder coated champagne. Looks much better than black. Winter tires on; 265/275. These wheels are perfect for the 550 and will also look good on my M5. And, yes, I can actually feel the weight difference compared to the OEM 20" cast wheels.
12-27-2021, 09:38 AM | #162 |
Rep 71
Agreed. 265/285 would also look fine. 275/305 was too much indeed.
01-13-2022, 12:43 AM | #163 |
Rep 12
M5 343M wheels are a perfect fit for the 535i M Sport. For the aesthetics of matched diameter and sidewall height I chose 255/295.
Front: 255/35/R20 Rear: 295/30/R20
2011 BMW 535i 6 Speed Manual RWD in Titanium Silver Metallic and Black Nappa Leather Interior with M Sport Package Premium Package 2 Chrome Delete
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34 Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20 Last edited by MuonShowers; 01-17-2022 at 12:02 AM.. |
01-13-2022, 08:56 PM | #164 | |
Rep 1,062
What tires are those? They look pretty stretched for a 295 on a 10" wheel. I ask because your fit looks great, but most people with 295 rear on 343m have rubbing issues and have to add camber to clear. Last edited by Blue Angel; 01-13-2022 at 09:16 PM.. |
01-16-2022, 03:11 PM | #165 | |
Rep 12
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34 Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20 Last edited by MuonShowers; 01-16-2022 at 04:45 PM.. |
01-16-2022, 04:36 PM | #166 |
Rep 12
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34 Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20 Last edited by MuonShowers; 01-16-2022 at 08:31 PM.. |
Blue Angel1042.50 |
01-16-2022, 09:25 PM | #167 |
Rep 1,062
Aha! You did exactly what I was going to do - head to Tire Rack for some stats, I presume?
Well, using a narrow 295 is obviously a great fitment on 343m! |
01-24-2022, 07:54 AM | #168 |
Rep 6
03-03-2023, 10:27 PM | #169 | |
Rep 170
04-02-2023, 12:14 AM | #170 | |
Rep 170
07-15-2023, 12:32 AM | #171 |
Rep 58
Dont mean to bring up an old thread but i have a 2016 bmw 550i xdrive awd with the dynamic handling package, i was wondering i need spacers for the front rims to fit?
Also what size tires would i need? |
08-15-2023, 04:16 PM | #172 | |
Rep 170
https://www.ebay.com/itm/22351678066...QwZe6ySyIi3LAo |
11-15-2023, 01:46 AM | #173 | |
Rep 143
What was your solution eventually? I am running into the issue of the vibrations on a 5mm spacer? |
11-15-2023, 07:09 PM | #174 |
Rep 1,062
12-12-2023, 02:13 PM | #175 |
Rep 847
Read through the thread and wanted to double-check before committing.
2016 LCI F10 xDrive 535d optimal spacerless 343M tire fitment: F 245/35/20 R 285/30/20 I am not looking for a stretched look and hoping 245 won't be stretched. Should I opt for the 255 fitment instead or leave as-is? Thanks for all the posts. |
12-18-2023, 04:57 PM | #176 |
Rep 2,595
245 will look a tiny bit stretched, but not that much. 285 will be almost perfectly squared up sidewall. 275 will be as well.
You can also run a 245/40/20 F and 285(or 275)/35/20, if you want some more sidewall. More sidewall helps with the front looking a bit less stretched. I personally run 245/40/20 F 275/35/20 R, and experience no rubbbing even when lowered pretty aggressively on my KW v3's.
2015 BMW 535xi
Blue Angel1042.50 |
