2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Forgestar F14 Super Deep Concave F10 Fitment Guide.
      08-01-2017, 11:18 PM   #155
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Originally Posted by Teddylongtooth View Post
Originally Posted by ey2001 View Post
If Lacster is running 20x9.5 et 11... wouldn't the 20x9.5 et 18 go in more?
He modified his car to make those fit, he pulled his front fenders and ran alot of tire stretch to make that work. I have 20x9 +28 on my fronts and they are flush, those wheels your looking at will stick out 17mm more than mine. But it depends on the look your going for? His car was slammed on kw coil overs and basically stanced, I bet a million dollars those rubbed. If you read this whole thread there alot of people who claimed they were going to do what he did but nobody did. I know the rears will rub, I have 20x11 +38's and they rub with no negative camber, so what you really needed ask was will these fit with or without a lot of modification. Those offsets will not fit without modification and trying different tires sizes and they will rub.
Cool. I'm just saying about the offset et18 vset11
      08-02-2017, 04:25 AM   #156
remmib
remmib's Avatar
Norway
1573
Drives: 2013 F10 520d M-Sport
Yes, the ET18 will sit 7 mm more in, but it still a aggressive fitment.
      08-02-2017, 09:34 AM   #157
ey2001
ey2001's Avatar
310
Thanks so what should the offset be for 20x9.5 and 20x11 or 20x10.5? I am on kw v3
      08-02-2017, 09:44 AM   #158
remmib
remmib's Avatar
Norway
1573
I've got 20x11 ET46 with 295/30/20 in the rear without rubbing.
Not sure what the best offset for 20x9.5 is in the front, it also depends on tiresize, 245 vs 255. I've got 20x9 ET26 with 255/35 tires, any lower than ET22-23 and you might start to rub over bumps, especially if you turn the wheel slightly.
      08-03-2017, 12:41 AM   #159
ey2001
ey2001's Avatar
310
Originally Posted by exia_m3 View Post
im on front deep concave 20x9.5 et 22
and rear super deep 20x11 et 40 super flush no rubbing
my only remorse should of went super deeps all around might just buy 2 wheels later this spring for that look T_T
Why didn't you go sdc? They have 20x9.5 with same offset? Just curious because I am planning to get the same setup..
      08-06-2017, 06:04 PM   #160
ey2001
ey2001's Avatar
310
What about 20x9 in the front +25 and 20x10 +40
      08-06-2017, 07:38 PM   #161
remmib
remmib's Avatar
Norway
1573
That's fine.
      08-06-2017, 09:50 PM   #162
ey2001
ey2001's Avatar
310
That's fine.
Thank you!!
      05-14-2019, 05:05 PM   #163
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
on a 2015 535xi lowered on H&R springs is 20x9.5 +12 20x10.5 +35 Super Deep Concave all around with 245/35/20 275/30/20 tires going to work? Is this going to clear regular brakes? Do you think there will be rubbing?
      09-02-2019, 10:15 PM   #164
ayeplussjr
Drives: BMW 535i M Sport
Is anyone running a 20x9.5 +22 deep concave fronts with 255/35 tires with no drop? My F10 is sitting stock with M Sport suspension. I don't think I have any plans on lowering the car since the wife drives it. I've seen some issues in these threads with rubbing with the 255/35 tire with the car lowered. I'm hoping that I don't have any issues with rubbing with the M Sport suspension. Am I better off with 245/35? I just don't like the tire stretch with the 245/35's though.
