09-29-2013, 06:45 AM | #1 |
Rep 501
Drives: 2015 M4
M6 rep off-sets
Hi all - I'm thinking about doing the M6 reps on my '11 550 - the off-sets seem way out - Front Size 20x8.5
Offset 37 Rear Size 20x10 Offset ET 33 Will this be an issue for fitment on the 550? Also, does a higher value offset equate to a more aggressive fitment? Thanks
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
09-29-2013, 07:15 AM | #2 |
Rep 921
I'm running almost the same sizes on my M5 reps except my fronts are 20x8.5 et35 and rears are 20x10 et33 and the rear are perfectly flush, the fronts could use a 10-12mm spacer to sit just like the rears. I'm not lowered yet but I plan on running H&R sport when I do lower.
As far as offset, the lower the number the further the wheel sticks out. Here's a pic of mine |
09-29-2013, 09:35 AM | #3 |
Rep 501
Drives: 2015 M4
Thank you Dan - those wheels look sweet on your car - I just seen your previous post - I also found the M6 reps on eBay. So, the 2mm delta should not make a major difference - think I'll order today.
