2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone mounted original M5 343M 20" rims on an F10/F11
      12-02-2016, 06:28 PM   #133
jjh2oman
jjh2oman's Avatar
Drives: 2014 BMW 550i
I just went through the same thought process. First for tires 245/285 is what you'll want because a 295 will rub. Next fitment, 2014 models need a spacer. Some have used a 3mm or 5mm without issues but you run the risk of vibrations at high speed because the wheel is no longer contacting the hub much if at all (i.e. no longer hubcentric). A 10mm is the smallest spacer with a hub on it to prevent the issue, but you may poke out a bit up front. I decided against it on my 2014, but would love to see how it looks on yours if you get them set up.
Just a squirrel trying to get a nut
      12-03-2016, 05:59 AM   #134
amrh
Drives: 2023 M3Cx
Could the fronts from the M6 be used, and rears from an M5? Then spacers wouldn't be needed for the front.
I believe they're 20x9.5 31 offset. Or, maybe they won't be flush?
      12-03-2016, 08:55 AM   #135
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
But then you only have 0.5" stagger between the front and rear wheels.
      12-03-2016, 08:57 AM   #136
amrh
Drives: 2023 M3Cx
Great point!
      12-03-2016, 05:19 PM   #137
Thieutje
24FITcoach
Thieutje's Avatar
Belgium
32
Drives: BMW F11 M550xd
That's a real bummer, is there a picture of those fronts with a 10mm spacers somewhere?
Can't find one.
I don't want the wheels to stick out of the car
      12-03-2016, 05:20 PM   #138
jjh2oman
jjh2oman's Avatar
Can't find one.
I couldn't find any anywhere, that's why I decided to pass on them. But it may be possible, 5mm more than the flush 5mm spacer which isn't huge.
      12-03-2016, 06:34 PM   #139
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Just mounted some 343's on 285. Fits well, and is flush.
      12-03-2016, 06:57 PM   #140
jjh2oman
jjh2oman's Avatar
Yeah, pre-facelift is great, they just mount right up and look amazing. Nice set there.
      06-29-2017, 10:43 AM   #141
marcinof10
Drives: e46 M3
is the caliper issue only the case on 550 LCI ?
535's are fine?
      07-21-2017, 07:48 PM   #142
BMW535MSPORT
BMW535MSPORT's Avatar
Drives: 2014 BMW 535i XDrive M SPORT
20" M5 343M rims on 2014 535i XDrive M Sport
I am running stock suspension with 255/35 Front and 285/30 Rear with zero problems. Rides great handles great.
http://www.bimmerfest.com/forums/sho....php?t=1021529
2014 BMW 535i X Drive M Sport
Carbon fiber Performance rear deck lid, Carbon Fiber Mirrors, Carbon fiber front bumper spoiler, M Performance exhaust and 20" M5 343M wheels with MPSS tires
      07-25-2017, 07:57 PM   #143
2013F10
Drives: 2013 BMW 535xi
Does anyone know if this setup will fit a Non-M 2013 535i X-Drive? Need to know if I'll need spacers, etc...
      08-31-2017, 07:40 PM   #144
Pito11213
Drives: 2013 alpine white 528 xdrive
I settled for replica 19" 245/35/19 and 275/30/19
Love the look.
      12-16-2017, 03:46 PM   #145
FElleven
Drives: F11 M550d
Hi, I recenty bought F11 M550d LCI, which share same front brakes as 550i. I have a chance to buy used 343M wheels, but I need to void using spacers upfront, since 3mm or 5mm are not hub centric and on top of that BMW wheels have beveld hubs, thus the risk for vibrations is high. I came to idea to buy used 550i pre-LCI front brake calipers and brackets. Do you think this are interchargable? Can someone get part numbers for this?
      12-21-2017, 04:33 PM   #146
TonyT530
Drives: 2013 535i M Sport
Here's mine with the 343m.
      12-22-2017, 06:28 AM   #147
FElleven
Drives: F11 M550d
Best angle to show 343m concavity. But look from the straight/side I don't like so much, they somehow look to "empty" and I prefer some more "full" wheels.
      12-22-2017, 03:23 PM   #148
TonyT530
Yeah i agree. Look nicer up close.
      03-13-2019, 11:28 PM   #149
H82walk
Drives: Bmw 535i
The oem m5 wheels will rub on the rear fenders with sumitomo tires 285/30/20 in rear. Haven't tried going with 275/30/20 but that might be the best bet. I have 255/35/20 upfront those are okay. I have a 2013 535i with the m package
      03-14-2019, 03:42 PM   #150
Freak1c
Freak1c's Avatar
145
Drives: 2018 M3 ZCP MW
Man your 343’s stick out a lot. Are those m6 343’s. Mine don’t stick out that much.
      03-14-2019, 03:55 PM   #151
E92hopefully
Drives: Non existent
Those have to be the m6 343 offsets
      03-18-2019, 05:09 PM   #152
M335
M335's Avatar
47
Drives: E90 n55 IG@FrozenF10
it’s definitely not m5 343m rims on the back unless he put some spacers
      07-25-2019, 03:59 PM   #153
super51fan
Drives: F10 535i
Has anyone ran 2 pairs of fronts in a square setup on an xdrive car? I know I could run 245/285 and be perfectly fine with staggered wheels but I'd rather be safe than sorry
      08-07-2019, 09:32 AM   #154
csmithbk718
Drives: 2014 500ix M Sport
What's been your experience?
Been following this thread recently. Looks like a lot of folks with the same thinking I have. But, for those who have applied it, I'm curious on your experience and results so far? I have a '14 550 Xdrive and I want to put 343's staggered with 245 fronts and 285 rears with a 5mm spacer in the front. If you've done this already, what's been your experience? Curious before I pull the trigger. Thanks.
