09-28-2019, 09:12 AM | #1 |
Rep 4
Raccoon vs Fog Light
Call it a draw ... raccoon sacrificed his life to push the fog light back. Broken bracket is my guess.
Tell me the M Style bumper cover does not need to be replaced to have the fog light re-attached? near as I can tell the lamp bracket has broken. bezel is fine. |
09-28-2019, 09:43 AM | #2 |
Rep 14,521
any pictures?
09-28-2019, 12:22 PM | #4 |
Rep 4
other option - replace bezel with the black that matches the lower air intake on center and forget it has fog lamps.
09-28-2019, 12:25 PM | #5 |
Rep 4
550i distant pic
09-28-2019, 02:22 PM | #6 |
Rep 659
I would have to say it needs to come off to find out what all is broken.
lsturbointeg9161.00 |
09-28-2019, 03:01 PM | #7 |
Rep 7,519
Did you try looking for removal instructions on the TIS website (if there aren't any in your owners manual)? If not...click link, type in the last 7 digits of your VIN, then type "remove fog light" in the search box: www.newtis.info
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
09-29-2019, 07:25 AM | #8 |
Rep 14,521
this! remove the bumper and see what exactly is damaged and what needs to be replaced. makes things easier as there's a lot of components you can't see until you dig in more. good luck
10-03-2019, 03:28 PM | #9 |
Rep 7
Wow, you lucked out! I hit a raccoon at same spot on the front end. Ended up costing me $2600, $900 of it was the new bumper cover, $250 for a new foglight, and lots of black plastic ducting & stuff.
There's lots of black plastic parts behind the bumper cover that could be damaged / gone. |
10-04-2019, 11:17 AM | #11 |
Rep 14,521
Dude, I couldn't drive around with my front end looking like that
