2010 2011 BMW 5 Series Forum F10 Persistent drivetrain malfunction |
06-15-2021, 11:44 PM | #1 |
Rep 118
Hi all, I've had this problem in my 2011 n55 for about 3/4 years already. Once in a while, I wanna say 3 times a year, I start the car and when driving, it feels engine is not making enough power. If I step on the gas, that would trigger a drivetrain malfunction message, followed by the car misfiring and running pretty rough. I switch off the engine, switch back on and car drives normal. At chasing this issue, I've replaced:
All coils All injectors Vacuum hoses HPFP Plugs Valve cover and gasket Vanos solenoids Breather hose Maf sensor Camshaft position sensors. After other engine and suspension parts, I wanna say I've spent around $12 k in the last 3 years trying to fix the issue. Car runs strong, but once in awhile this problem shows up. Codes are misfires on all cylinders plus p0171. Has anyone encounter this issue? I'm so done with trying to drive the car without being scared of the engine exploding one day. Thank you for your help. |
06-16-2021, 09:59 AM | #2 |
Rep 210
IMO, the best way to figure this out is to log while this is occurring. Hopefully then you could narrow this down. Throwing parts at problems gets very expensive, as you know!
06-16-2021, 10:15 AM | #3 |
Rep 118
I have done that. Showed to mechanic and he even didn't have a clue what it could be triggering it. I guess I'll have to deal with the misfiring 3 times a year lol. Thanks for your input
06-16-2021, 09:41 PM | #5 |
Rep 231
I would suggest to get the real BMW code with ISTA or other BMW compatible scanner.
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
