2010 2011 BMW 5 Series Forum F10 Battery Discharging Warning |
04-05-2017, 11:43 PM | #45 |
Rep 5,365
My wife drives my old '12 535i only a few times a week (has ~82K miles). She will get the battery warning the first time she starts the car then doesn't appear again until she drives the car a few days later. It only appears on initial start-up. The battery was replaced, a year and a half ago. I have a 3amp charger but bought the BMW 4amp (it was only ~$60) charger to see if that extra amp helps.
04-06-2017, 03:14 PM | #46 |
Rep 161
Drives: 2014 535ix
I've kept this Optimate 4 charger on my BMW motorcycles and occasionally on my F10 if it sits too long. It's a desulfating/conditioning charger/analyzer.
https://www.amazon.com/gp/product/B001EBDXLM/
2014 535i XDrive Alpine/Mocha Nappa Contour
04-29-2018, 12:12 PM | #47 |
Rep 4,209
I've been starting to get this error more and more recently lately. I'm debating if I need to get a new battery or not. And from what I saw around the forums, there is some programming portion of installing a new battery (ugh)
04-29-2018, 01:30 PM | #48 |
Rep 538
Have you charged the battery up with a proper charger. If not then the message won't disapear as the car won't charge it properly.
10-24-2023, 03:21 PM | #49 |
Rep 55
I got this message yesterday and today what does it mean do I need to charge the battery or buy a new battery? What does the message mean for me the interior lights are not on when I open the car. Should I charge the battery or replace battery
10-24-2023, 04:55 PM | #50 |
Rep 264
Razfrankel,
Do you have Comfort Access door handles? If so that would be the first place I would look. Many Youtubes to help but basically you disconnect the comfort access and see if that resolves your drain. |
razfrankel3.00 |
10-24-2023, 06:43 PM | #51 | |
Rep 7,484
You need to find out why your battery is discharged. Is it due to its age? Or do you have something draining it? This warning is trying to get your attention because you may end up stranded if you don’t check into what the cause is. If it comes up again, press the OPTION button next to the iDrive controller and see if there is a selection that will take you directly to the embedded owners manual. It may offer some helpful description.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
razfrankel3.00 StradaRedlands4940.50 |
10-24-2023, 08:33 PM | #52 |
Rep 233
Drives: 2015 BMW 535i M Sport
+1 to what Qsilver7 and Trian have said.
Something is causing an increased draw of power while your bmw is stopped. Either something is not going to sleep correctly or something is grounding out. Charge your car up with a battery charger, read the hexadecimal codes to see if it is identifying the circuit, and keep an eye on your battery state of charge. For me, this issue occurred when I had a bad CA handle that would short out, but only when it rained and the car sat for a couple of days. |
10-24-2023, 08:35 PM | #53 |
Rep 251
I get this warning also, but my car is 8yrs old 60k miles so i figure its time to get a new battery but i believe i can sneak another mod in b4 i do that ijs.
10-24-2023, 08:38 PM | #54 | |
Rep 233
I am suprised tho at how long these AGM batteries do seem to last, especially when people keep them on chargers periodically. I've read many posts where people have had 10 yr old batteries. I'll be replacing mine before winter this year as PM (I'm @ 9 yrs). |
StradaRedlands4940.50 Double Nickel165.00 |
10-25-2023, 08:57 AM | #56 |
Rep 7,484
Did you read posts #50 - #54?
10-26-2023, 12:42 AM | #58 |
Rep 2,995
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
And the result was...?
10-26-2023, 07:56 PM | #59 |
Rep 251
Was curious on a good battery so i google'd one and fcp has one i guess. How you buy yours nowadays? Local parts box or local BMW shop orfcp? Do shelf life harm agm's? Im tired and need to order a Moly kit (oil,flush,ceratec) from fcp, might order a battery and just get it out the way
10-28-2023, 07:12 PM | #60 | |
Rep 7,484
The local auto shops wanted $239-$325 for a comparable 95R/H9 battery and all of them were only 100 AH batteries except the one from Batteries Plus…but they were the most expensive that was $325. So with my BMW CCA discount and core return…I was out the door from my local BMW dealership parts department for $227. It was also fresh (purchased it in Jan/2023) and it came with a little baggy attached that had an extra little black elbow (for attaching the vent tube to the battery) plus an additional plug to use on the other side of the battery. Call and check your local BMW dealership before dismissing them. If you can’t install it yourself…the the cost is going to be more.
10-29-2023, 10:11 AM | #61 |
Rep 2,995
Yeah, check with the dealer and see... I think BMW branded batteries are the best ones out there! I believe Exide makes them for NA market? Also check out Costco which carries Interstate batteries. They have been great as well.
10-29-2023, 11:05 AM | #62 |
Rep 171
O'Reilly. Super start H9 105AH, perfect fit if you are using the 105.
ctcarbonari292.00 StradaRedlands4940.50 |
12-04-2023, 07:39 PM | #63 |
Rep 55
I have the message every time I get in the car I have a solar battery charger I don’t think it’s charging the battery enough. Do I need a new battery or charge the battery?
12-04-2023, 10:45 PM | #64 |
Rep 5,365
You have a parasitic drain somewhere. The usual suspect is one (or more) of the comfort access door handles. Mine was the passenger, rear. Once replaced under warranty the problem was solved.
12-05-2023, 11:40 AM | #65 |
Rep 55
I have the message every time I get in the car do I need a new battery cause I have a solar panel charger I don’t know if it’s charging enough power. Do I need a new battery or charge the battery. Tell me what to do guys?
12-05-2023, 04:08 PM | #66 |
Rep 7,484
Where do you have your solar panel plugged in? Is it plugged into one of the cig lighters…or is the solar panel charger connected to the jump start terminals in the engine bay?
