2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Which Foxwell Scanner for F10
      04-25-2020, 01:20 PM   #1
aebas54
Drives: 2011 335xi
I have a 2013 535i 93k miles
I was unable to get the NT-510 Foxwell scanner to work with my vehicle. Which Foxwell scanner is compatible with this model? NT-530?
Thank you
      05-15-2020, 04:49 PM   #2
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
I have the same NT510 scanner and can only get it to work through the OBD2 setting and not the BMW settings
      05-15-2020, 08:06 PM   #3
wcr3d
Drives: 2013 535i XDrive M Sport
It is not which scanner version you have, it is which software you have loaded into that scanner.
      12-30-2023, 10:15 AM   #4
Midwaymonsters
Drives: 2013 BMW 535i
Thank you
Were you able to get that scanner to work on your 2013 535i?
      12-30-2023, 10:19 AM   #5
Midwaymonsters
So the Foxwell NT510 Scanner should work on my similar 2013 535i as long as the software is updated?
      12-30-2023, 05:23 PM   #6
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
The Foxwell scanner NT510 will have limited functionality, as it's hardware is not fully compatible with F series vehicles....you'll need to get the NT530 version.
I had the same issue and reached out to Foxwell support, and they told me no amount of FW update will allow the NT510 to fully work with the F10. It's not always a limitation due to BMW....see note below.
So I purchased the NT530.
Note: I also have a 991.1 (older) variant of the Porsche 911, which I needed a scanner to reset the service indicators, which required also to enter the date of the service light reset, and found out that the NT510 HW could only support dates pre-2020...so in order to show the date of service reset past 2020, I was forced to purchase the NT530.
      01-01-2024, 11:04 AM   #7
Midwaymonsters
Good to know, thanks so much!
