2010 2011 BMW 5 Series Forum F10 Serpentine belt and Tensioner |
01-31-2021, 05:00 PM | #1 |
Rep 1,254
I think my tensioner is starting to make noise
2013 550i N63 engine 65kmiles I couldn't find anything on YouTube how to replace it. Could it be that hard that people just fork out cash to dealer. If any of you have done this please give me some direction. Or some technical data instructions would work just fine. Thanks
01-31-2021, 06:28 PM | #2 |
Rep 915
I'm sure this is somewhat similar?
Instgram @burninja
01-31-2021, 06:47 PM | #3 |
Rep 175
I’m about to do a full water pump replacement on mines this week after doing a visual inspection and the water pump pulley is twerking around while running.
I’ll be replacing all the belts, pulley and tensioner in the process. I’ll report on it once it’s being done. Mines finally gave right at 130,002 miles. |
EL Jeffe 5611.50 ChiltiCoatl891769.00 |
02-01-2021, 04:21 AM | #5 |
Rep 639
I know on my N55 and my previous BMW it was fairly simple. The tensioner can be adjusted using a large torx socket and long breaker bar to release the belt. Then there should only be one bolt holding it onto the front of the engine. The new one is the bolted on and the belt fitted, then you use the same torx bit and bar to put some tension on it and remove the shipping pin that holds the tensioner in place for assembly.
I would also say replace any idler pulleys that are in there at the same time. Usually fairly cheap and easy to replace too. |
550bye1389.50 ChiltiCoatl891769.00 |
02-01-2021, 10:15 AM | #6 | |
Rep 1,254
I think I will have to remove cooling fan to gain more space
02-04-2021, 12:22 PM | #7 | ||
Rep 639
02-04-2021, 02:23 PM | #8 |
Rep 2,591
Just keep in mind, the cross brace that connects at the front of the car and at the strut tower has a TTY bolt. You have to replace it with a new one or you will strip out the hole at the strut tower - ask me how I know lol
It's the only annoying part of removing the fan.
2015 BMW 535xi
02-05-2021, 11:18 AM | #9 | |
Rep 1,254
Thank you so much for heads up
02-05-2021, 01:54 PM | #10 | |
Rep 965
02-05-2021, 10:47 PM | #11 | |
Rep 2,591
Eh, there's a time and place for TTY bolts. As a suspension component, it makes sense.
2015 BMW 535xi
Sylverlee150.00 |
02-06-2021, 04:48 PM | #12 |
Rep 175
Did mines with the water pump, pulleys, tensioner and belts.
Couple things to remember: It is easier to do with the fan removed but not required if you are planning to change JUST the tensioner. All access will be from the bottom of the car with the engine belly pan removed. When changing belts, especially the a/c belt where it is mandatory to remove the 4 bolts holding the main engine pulley is that you keep the engine from rotating and ONLY ROTATE CLOCKWISE. NEVER ROTATE BACKWARDS. ^^ doing so will damage your cam gear assembly causing potential engine damage never did that on mine since I remember when I did my valve seals last year. The tensioner uses a T-60 torx tool and it is under high tension so be careful. Use good belts. Don’t cheap out here. Last edited by 550iFreak; 02-06-2021 at 05:53 PM.. Reason: Correction. |
EL Jeffe 5611.50 |
02-06-2021, 05:21 PM | #13 |
Rep 2,591
Which tensioner are you talking about? The one for the water pump/alternator belt is not TTY, it's 40nm and that's it.
2015 BMW 535xi
02-06-2021, 05:52 PM | #14 |
Rep 175
Hmmmm I thought I read that the bolt was supposed to be replaced with the tensioner.
Reread the newtis manual and you’re right, 40nm with no mentioning of the replacement of the bolt. Sorry about that, edited top post. Still, it is a peace of mind having new hardware. And it was really cheap so no worries there. |
02-06-2021, 06:08 PM | #15 | |
Rep 2,591
2015 BMW 535xi
02-07-2021, 06:22 PM | #16 | |
Rep 1,254
Did you replace all three belt pulley and tensioner Thanks
02-07-2021, 06:34 PM | #17 |
Rep 175
There was only two belts. The AC belt and the main alternator/water pump belt. Both are replaced with genuine continental replacements along with BMW water pump, BMW tensioner and bolt, and BMW deflector pulley.
EL Jeffe 5611.50 |
01-12-2024, 04:36 PM | #18 |
Otaku
Rep 21
Came here for information but was surprised at this. I'm at 131k and I'm barely researching replacing the circa 2016 spark plugs much less the pulleys and belts
2016 LCI 550i Glacier Silber |
