2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Valve cover gasket pinched slightly need help
      12-23-2023, 05:33 PM   #1
wesamjaber2004@gmail.com
wesamjaber2004@gmail.com's Avatar
Drives: Bmw 535i
Hey guys so I did the valve cover gasket job a little while ago and the install went smooth but I’ve been dealing with a slight idle vibration and slight jerking while idle, rpm’s don’t jump and car still pulls hard while tuned but I smoke tested the car and turns out I pinched the gasket very slightly on the right side. It’s not leaking oil but it does have a vacuum leak that is sooooo small it makes me not want to redo the job.
Do you guys think I should use permatex or some type of sealent ? The leak is so small that smoke barely came out at all it was such a small amount. Any advise would be appreciated.
      12-23-2023, 09:02 PM   #2
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
I would suggest to redo the gasket, I would do more research as well as wait for a reply for those who have used Permatex before.
      12-23-2023, 09:19 PM   #3
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
As you said, a slight vibration and jerking, so that's a re-do. :-(
But hey, should go a lot faster the second time!!!
      12-23-2023, 09:25 PM   #4
Drives: Bmw 535i
It isn’t a bad one though it’s just a noticeable one if you get my drift. And thankfully no codes or enough leak to trigger a boost issue, still able to push this thing 😁
But I do like having a luxary first car too so I’ll just redo it if I don’t find a solution. Sucks Becuase it’s not even an oil leak, I was off by just a smidge.
      12-23-2023, 09:43 PM   #5
ChiltiCoatl89
Yeah, for now, its fine however, that is a compromised area, the sooner the better, I definitely wouldn't want to neglect that any longer than needed my friend.
      12-23-2023, 10:03 PM   #6
Drives: Bmw 535i
Very true, hopefully sometime over the next few weeks I’ll pay my friend who’s a bmw tech to do it.
      01-10-2024, 02:05 PM   #7
Drives: Bmw 535i
So we ended up doing the valve cover gasket and extracted the 2 broken bolts in the head, my car is good now thank god. Can’t believe I neglected it for this long. We now have to replace the vaccum line that connects to the intake inlet but that shouldn’t be big to do at all. He did it all for 600 as well as rethreading the holes and smoke testing. At a dealer it prob would’ve been 2000+ 🤣I for sure got my bang for my buck.
      01-11-2024, 02:53 AM   #8
ChiltiCoatl89
Awesome news!! Glad the 5er is back 100%
      01-11-2024, 07:51 PM   #9
StradaRedlands
2006 Mazda3  [5.50]
And it sounds like you found a keeper of a mechanic!
If they do coding as well, you're set up sweet!!!
