2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum how do you adjust parking mirror?
      01-06-2017, 07:55 AM   #23
Quicksilv3r
Quicksilv3r's Avatar
Drives: 2013 BMW 535i M-Sport
IIRC you can change the tilt quite easily. Move mirror selector to driver position and put car in reverse to activate the tilt. Then, when the mirror has fully tilted, switch the selector to the passenger side mirror and adjust the mirror angle upward until desired level, then switch it back to the driver side mirror and it should hold that memory the next time you put the vehicle in reverse.
I didn't drive mine to work today or I'd go out and try it to make sure.
-WJV
      01-06-2017, 11:22 AM   #24
Originally Posted by corys530 View Post
P
My mirrors don't fold if i press the lock button a little longer, like the previous poster said..would be nice?
Can be coded....
      01-06-2017, 05:09 PM   #25
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Personally i like the tilt down feature, i can see the curb or the parking lot divider lines perfectly! My only complaint is its too slow and sounds like an old style gear drive...ha
My mirrors dont fold if i press the lock button a little longer, like the previous poster said..would be nice?
I like tilt for parallel parking. I use 5DL for parking lines. My mirrors are really quite and quick, except for defrosting.
Do your mirrors fold when you press drivers side inside door button?
      01-06-2017, 09:05 PM   #26
Gpfarrell
Drives: 6MT Imperial Blue 550i M-sport
That's interesting... and a cryptic enough process that it sounds like the BMW way!
      01-10-2017, 11:59 AM   #27
gicamuci
Drives: 535ix
For us in NA that is deactivated by default, but it can be coded to enable it. And if you have comfort access you can also code to fold them when you long touch the door handle.
2012 Mercedes-Benz C350 4MATIC Black/Sahara
2011 F10 535i xDrive MY 01/2011 Sophisto Grey / Black
      12-28-2023, 07:00 AM   #28
hackeron
hackeron's Avatar
Drives: BMW 520D 2016 (F10)
On my 520D F10 2016 no matter what position the mirror adjust switch is in, when I put the car in reverse the mirror doesn’t tilt down. Seems this feature is missing on mine, is this a hardware feature or something that can be enabled/coded?
      12-28-2023, 02:01 PM   #29
I know the dip-angle is codable, so maybe you can use that coding?
      12-29-2023, 02:17 AM   #30
Almaretto
Almaretto's Avatar
2374
It is not a standard feature. If you do not have electronic dimming and controllable mirrors then you are missing hardware.
