2010 2011 BMW 5 Series Forum F10 Charcoal Canister and Detection Leak Pump on an F10? |
11-19-2018, 12:52 PM | #1 |
Rep 318
Hello guys, any one of you know where's the Charcoal Canister and Detection Leak Pump are located on a 2014 535i? Thanks in advance for your help guys.
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i '19 G01 X3 | Wife's '15 F30 335i M-Sport | Son's '10 Porsche Boxster |
11-19-2018, 05:05 PM | #2 |
Rep 76
I am not sure if Charcoal Canister is in there too but Leak Detection sensor and filter are located behind rear passenger tire, in the tire well. Just remove the tire and well cover to get to it.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
11-19-2018, 07:33 PM | #3 |
Rep 318
Thanks a lot ! Actually I'm looking for the leak detection pump, thanks for the info ! 👍🏻😉
11-19-2018, 08:19 PM | #4 |
Rep 231
Do you get any fault code?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
11-20-2018, 08:19 AM | #5 |
Rep 318
11-20-2018, 10:46 AM | #6 |
Rep 76
I believe it's used to be called Purge Valve in old BMW's. It is located behind passenger rear tire in the tire well. It is a leak detection pump and must be replaced along with the filter. There are 2 kinds and depends on the year model you may have one or the other. Check before you purchase one.
11-20-2018, 06:33 PM | #7 |
Rep 231
I had the similar issue (code 190302) and went to dealer 4 times. Eventually, dealer replaced the DMTL module to solve the problem. Luckily it was under warranty.
Tags |
dtml detection leak pump |
