2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Cylinder 5 misfire
      06-11-2023, 11:34 AM   #1
Sly_535i
Drives: 2014 BMW 535i
Cylinder 5 misfire
Hello all, I am dealing with a very frustrating misfire on my n55. It has a slightly rough idle on cold start for only about 1-2 minutes then it smoothed out. Once the engine is warm it only misfires under boost. If push the gas pedal more than 1/3 of the way it misses pretty hard and eventually throws codes for cylinder 5 misfire and fuel deactivation. I bought the car a few months ago and this is my first BMW so I’m not too familiar with the platform. As of right now the car is on a MHD stage 1 tune, catless DP, and upgraded charge pipe.
Recently it start misfiring so I threw in some new Bosch OEM plugs at stock gap. It still misfired. Then I tried replacing the coils with OEM Delphi coils, it still misfired. I sent a picture of the codes the DME threw for the misfire to a tuner and he said to try changing the injector because it could be stuck open. So I changed it with a Bosch EU5 injector and coded the flow rate in to the DME. It still misfires. I don’t know what I’m missing here but I would really appreciate some help. TIA
      06-11-2023, 05:33 PM   #2
paul223
paul223's Avatar
Drives: F10
Is there voltage coming to that particular spark plug?
      06-13-2023, 01:32 PM   #3
Sly_535i
Yes, it only misses during high load
      06-13-2023, 09:44 PM   #4
Sly_535i
Now I’m getting cyl 1 and 2 misfire. Here’s a log if that helps https://datazap.me/u/sly535i/613-log...1&zoom=104-484
      11-15-2023, 07:53 PM   #5
00866b
Drives: Bmw 535i
Check my thread I’m in the same boat as yours.
      11-16-2023, 02:21 AM   #6
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
Possibly Voltage related, check your Wire connections Also, how do your intake valves look?
