2010 2011 BMW 5 Series Forum F10 BMW F10 535i Xdrive Transfer case, Front, and Rear Differential Procedure? |
02-26-2020, 10:10 PM | #1 |
Rep 199
Is anyone experience with changing the fluid in the above mentioned areas? What types of fluid will I need and if possible, links? Thanks
02-27-2020, 12:30 PM | #2 |
Rep 17
I just did front and rear diff in mine. I used Liquimoly 75w-90 for both. FCP Euro sells a change kit with plugs. Looks like BMW switched to 75w-85 for later build dates, I'm not sure if it really matters. You need to suck out the rear fluid with a pump and a hose with a bend or I used a bent brake line to reach the bottom of the diff. There's YouTube videos for the rear diff. For the front you need to take off the bottom front cover that looks like thin carpet then the metal shield under the oil pan. Then you'll see the diff drain plug and the fill plug is on the driver side close to where the axle connects. They sell a wrench to get to it from the bottom but I took the side plastic off the driver side wheel well with an extension and a wobble on a 14mm hex socket. You'll need the pump or just the rubber hose to fill with the new fluid too.
02-27-2020, 04:03 PM | #3 | |
Rep 2,591
Also, isn't OEM rear diff fluid GL-4? The liquid moly and red line ones are all GL-5. Dunno if it's safe to replace GL-4 with GL-5
2015 BMW 535xi
02-27-2020, 09:55 PM | #4 |
Rep 17
The front was less than 1L, maybe 3/4. Rear was 1L, so you need to buy 2L anyway.
I think it depends on your build date, looks like they went from gl5 to gl4 but the diffs between dates are still the same part number. ECS has liquimoly gl4+ if you want to use that one. I don't think the diffs are that sensitive between the two different fluids, unlike the transfer case. Looks like BMW switched to 75w-85 for build dates after 6/2011, but the oem BMW 75w-85 fluid is offered as gl4 or gl5 for the exact same diff, that's why I think it's up to preference. |
02-28-2020, 04:58 AM | #6 | |
Rep 455
The transfer fluid I used... https://www.ecstuning.com/b-shell-pa...222409710~shl/ |
02-28-2020, 05:50 AM | #7 |
Rep 1,873
I did front/rear last spring. Transfer case will be this spring.
Choosing a fluid seems a little - tricky. I am, generally speaking, an "aftermarket" fluid kind of guy. I've used Redline or Amsoil (heavier emphasis on Amsoil in recent years) in the drivelines of all of my cars with success and savings. The catch is that in all of those cases, the specifications of the original fluids are pretty straightforward, and matching requirements using non-OEM fluids has been pretty easy. I found the F10 was trickier. Using my own research, the Internet, the dealer Parts counter and the dealer Service rep, we had some difficulty. For the rear diff, BMW says this: https://www.newtis.info/tisv2/a/en/f...ide/1VnczONFlo To me this translated to the vehicle almost certainly coming with SAF-XO. This has been a rear diff fluid for decades and is essentially any GL-5 75W90 gear oil. Easy peasy. For the front diff, BMW says this: https://www.newtis.info/tisv2/a/en/f...ion/1VndAkI4Dp This clearly indicates that SAF-XO, Synthetik OSP and all the other "rear diff" fluids are NOT recommended for my front diff. The parts system seems to further confuse things with supercession history, date limits that are confusing etc... https://www.realoem.com/bmw/enUS/sho...diagId=31_0871 Further, different part systems (like ETK at the dealer, and bimmercat, show slightly different details. There seems to be a magic build date in 7/2011 where different fluids are forbidden on one side or the other, but none of the hard parts seemed to change on that date. I have a 3 or 4/2011 build date. So, in the end, I ended up with Amsoil SVG in the rear and genuine BMW G2 in the front. It was expensive, but SAF-XO is expressly NOT recommended/allowed so I wasn't taking the chance on some internal corrosion damage resulting from my insistence on an aftermarket fluid based on the confusing presentation of acceptable/recommended fluids from BMW. For the transfer case, nothing but OE all the way. It's very exotic and has also been updated a couple of times. I'll buy it from somewhere less expensive like FCP though. |
02-28-2020, 09:10 AM | #8 |
Rep 17
No problem. I haven't had the time yet. Looks like I'll just take the fill plug out and use a pump with a bent brake line but cut the flare off the end so it's smooth and won't get hung up on a gear to reach the bottom of the case and suck out the old fluid. Then fill with bmw fluid or the oem ATC fluid since ATC makes the transfer case. I believe you need to reset the transfer case adaptions afterwards. I'll be using ISTA, maybe you can use another program.
02-28-2020, 09:39 AM | #9 | |
Rep 17
02-28-2020, 09:44 AM | #10 | |
Rep 1,873
It says only G2 for the F10 (and most other models). This is the "conflicting" information of which I speak. For the REAR, many fluids are OK. For the front, TIS says only G2, ETK is less specific implying that many work. Personally, I like the TIS bulletins dated recently clearly stated what fluids are acceptable at the time of publishing. |
02-28-2020, 10:47 AM | #11 | ||
Rep 17
02-28-2020, 03:26 PM | #12 | |
Rep 1,873
Why are they so specific about fluid for the front diff when the rear can use a wide range of fluids? I have no idea, but there's probably a reason. I don't buy the conspiracy theorists who believe that BMW would do something like spec an oddball fluid in one component just to generate extra revenue when vehicles are in for service. They themselves say you never have to change that fluid, in theory. Maintaining a special fluid in parts and inventory must have a reason. I just wish I knew what it was. Sometimes it's working around problems discovered in the field after failures. |
02-28-2020, 11:31 PM | #13 |
Rep 965
I used this on my 2013. Running well.
Red Line 50504 MT-85 75W85 GL-4, 1 Quart, 1 Pack https://www.amazon.com/dp/B004D4URV6/ref=cm_sw_r_cp_api_i_.BFwEb394NSA3 |
02-29-2020, 06:19 PM | #14 | |
Rep 2,591
2015 BMW 535xi
02-29-2020, 10:35 PM | #15 | ||
Rep 199
02-29-2020, 10:38 PM | #16 |
Rep 199
Also, change of subject, but does anyone know how to drain the coolant on the f10? I'm assuming it's a quick lower radiator hose pull and drain. Hahaha too lazy to start a new thread
02-29-2020, 11:38 PM | #17 | |
Rep 199
03-01-2020, 01:46 AM | #18 | |
Rep 2,591
2015 BMW 535xi
03-01-2020, 07:22 AM | #19 | |
Rep 1,873
In my research it wasn't that hard to get to, but not as easy as on the X cars obviously. I have some low profile hex sockets that should be able to reach up to the fill hole OK. When I did the transmission, I removed some heat shielding to give easier access to the fill hole. I can't remember if there's a similar helpful step for the transfer case. |
03-01-2020, 08:40 AM | #20 | ||
Rep 199
03-01-2020, 11:49 AM | #21 | |||
Rep 17
03-01-2020, 07:14 PM | #22 | |
Rep 2,591
It's the fluid I'm planning on using, yep.
2015 BMW 535xi
