2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2014 550i drive train CLUNK
      06-15-2021, 05:43 PM   #1
Dahigi777
Drives: 2014 BMW 550i Stage 2
So all of a sudden my 550i clunks really hard when I am driving and take my foot off the gas to coast. About half a second after I take my foot off the gas, probably about 75% of the time, and the few times that it doesn't do it, it happens as soon as I start to press the brake. Doesn't seem to matter what gear, but seems when the car is at lower rpms (pedaling around a parking lot) ita more likely to happen. Loud metallic clubk sound that can be felt inside the car, very cringey when it happens. Never noticed it until the last week or so. Aside from that, completely smooth gear changes and no slipping otherwise. Kinda seems like it either doesn't want to let go in time, or it trys to grab the next gear when its not supposed to. I had a shop drop the pan and do the filter and refresh some fluid about 15k miles ago. Haven't seen any leaks or anything and I know its a super pain to check the level without being equipped to do it. Seems to come from the center of the car, but can't really say if its transmission or maybe drive shafts. Anyone have any idea of quick fixes I could try or perhaps what to look for if I were to get it up on a lift? Appreciate it.
      06-15-2021, 06:15 PM   #2
chipguy
Drives: 12 528i
I would check the flex discs and the bushings for the differential.
      06-15-2021, 11:27 PM   #3
Dahigi777
From my research flex disc's are similar to u-joints? Do they connect shafts to each other? Its a little tricky finding things in the workshop manuals but I'm gonna try to find it.
      06-16-2021, 12:05 AM   #4
chipguy
Drives: 12 528i
No they are not u-joints. Search BMW rubber discs and you will see plenty of pictures. One disc connect the transmission to driveshaft and another connect the driveshaft to the differential.
      06-16-2021, 07:28 AM   #5
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
+1 on the guibo. Those tend to go bad every 40-50K, so if it's never been changed, definitely a culprit. The rear diff [rear] bushing is also a common fault. That you should be able to see by just sliding under the car from the rear without even raising it. It's easily visible. The guibo will require removal of the entire exhaust and the heat shields. Not necessarily hard, but just a PITA. Both are DYI if you're handy enough on cars.
This guy does both in same video. I followed his instructions to the tick and had no issues.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
walmark85.50
otay826.00
AlexL4.50
      06-16-2021, 08:47 PM   #6
Dahigi777
Awesome! Super helpful, I appreciate the info.
      03-02-2023, 06:32 PM   #7
Cali8055
Cali8055's Avatar
Drives: 2014 550i X Drive
I noticed my diff bushing & rear guibo need replacement . But noticed it has 2 and mechanic said he’d recommend to replace both mind as well . Are they both the same size ? I search up and only “ rear” one pops up . Thanks
      03-02-2023, 10:14 PM   #8
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
I ordered the same one, compared the original side by side and they are identical.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
