2010 2011 BMW 5 Series Forum F10 Anyone had 535xD transfer case issues? |
07-13-2021, 03:50 PM | #1 |
Rep 1
Bough this car about 1 year ago and sporadically had 'drivetrain malfunction' annunciator. Began getting progressively worse and more common.
I thought it was a bad VTG Control unit and bought a used, replacement online. I went through the process with ISTA during removal to read code (also verified with actual Transfer Case) and then coded the 'new' control unit through ISTA. When I get to the VTG Calibration, I get a 'No Valid calibration value stored in the VTG control unit' I've gone back through the repair/install procedure several times now with no change in calibration. It now gives the following codes with the used replacement VTG Control Unit: 440117: Four Wheel distributor gearbox temporarily shut down 440102: Oil Wear 440105: Calibration Faulty as well as DSC codes: 48068C: Transfer case - clutch temporarily shut down, possible overheating 48097D: Transfer Case - clutch poistion open, rear wheel drive only D355F8: Signal Error (xDrive actuator information; ID: XDRV_ACT_INFO) - Invalid Has anyone else experienced this? Am I looking at a failed or failing Transfer Case? |
02-05-2023, 10:11 PM | #2 |
Rep 93
What was your resolution, I am in the position with a replacement Transfer case and control unit. Every time I try to calibrate it, I get a "No valid calibration value stored in the VTG control unit"
I tried two separate control units with the same results. It happened on the original transfer case as well as the newly replaced (used) transfer case. |
