2010 2011 BMW 5 Series Forum F10 Does fuel injectors original placement order matter? |
02-08-2023, 03:23 AM | #1 |
Rep 179
Drives: BMW 535i F10
Hello, i had my car with engine mechanic for checking and when he took the fuel injectors off he didn’t put them back in the same place where they were initially (1st injector was put in place of 3rd and so on). I have read somewhere that fuel injectors need reprogramming after replacement and will it be necessary in my case? I didn’t replace them they were just put back in by different order. Might be a stupid question but want to make sure everything is fine..
02-08-2023, 05:58 AM | #2 |
Rep 1,873
Yes it matters. There is a unique flow rate compensation value printed on each injector which must be coded into the ECU.
lukavergille206.00 |
02-08-2023, 06:10 AM | #3 |
Rep 179
02-08-2023, 08:30 AM | #5 | |
Rep 179
Also shouldn’t I be getting errors becuase of misplaced 3rd and 4th injectors? |
02-08-2023, 09:55 AM | #6 |
Rep 179
I did misfire test on ISTA and it showed that there was misfire on Cylinder 3 and 5 when starting the engine. Would that mean that Injectors 5-6 are swapped too as 3-4 are?
02-09-2023, 03:32 AM | #9 |
Rep 179
Just confirmed that 5-6 are correct by mechanic. So i will just calibrate 3rd and 4th injectors. Should i reset adaptions after calibration?
02-09-2023, 06:35 AM | #10 |
Rep 1,873
As others said - you can recode the values into the DME (should have stated that in my post). You just wouldn't have to if they were inserted back in the correct spot. If they are mis-coded it will affect smooth idling etc...
Now - if your mechanic didn't know to put them back in the same place, do they know about the single-use parts and specific insertion tools/technique for the injectors? That would be my question. |
02-09-2023, 01:53 PM | #11 | |
Rep 179
I just found out about special insertion tools and technique. Th single-use parts - are you refering to decouplers and injection seals? He definitely hasn’t replaced them or anything else. Just took the injectors out for few minutes to check something and put them back in. So these single-use parts should be replaced even if injector was just taken out and put back in? |
02-09-2023, 07:22 PM | #12 | |
Rep 1,873
Some may say that the repair manual is too fussy and Mr. X has done Y and Z without doing any of the stuff in the manual, but these engines can be pretty picky. Can't link you to real factory manuals any more but this seems to have a lot of the stuff: https://bmwrepairguide.com/bmw-n55-f...r-replacement/ Note that the N55 has 3 styles of injectors: broadly they are EU5 or EU6, and within EU5 there is gen 1 and gen 2. Different puller tools, appearance and, obviously, parts required if you do the swap. |
