2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum New wheels suggestion?
      02-28-2023, 06:46 AM   #1
lukavergille
lukavergille's Avatar
Georgia
206
Drives: BMW 535i F10
2013 BMW 535i  [9.50]
Planning to upgrade to 20” wheels but can’t decide which one i like more. What’s your thoughts - which looks better?
      02-28-2023, 11:11 AM   #2
IMHO, the bottom set.
      02-28-2023, 02:24 PM   #3
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
My vote, for what it's worth, is the bottom style, but in silver or at least something lighter than black. I don't like black wheels, especially on a black car.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      02-28-2023, 02:33 PM   #4
Trian
Drives: 2015 535i M-Sport
The black ones if you paint the brake calipers.
      02-28-2023, 05:53 PM   #5
r2dmax
r2dmax's Avatar
Drives: E46 330ci; F10 535i M Sport
Pic the ones that will make YOU want to look back everytime you park. The ones your eyes are drawn to 1st
      02-28-2023, 07:58 PM   #6
Double Nickel
Double Nickel's Avatar
Drives: BMW F10
2015 BMW F10  [10.00]
Bottom but not black imo
      03-01-2023, 03:50 AM   #7
lukavergille
Georgia
206
Thanks for suggestions guys, i am tilting to bottom design with brushed silver finish
cdmulders326.50
      03-02-2023, 09:36 AM   #8
lukavergille
Georgia
206
Trying to find the correct wheel size now.
Current setup on rears are 275/35r19 on 19x9.5, ET38 wheels with 15mm spacers.
Wheels are sitting perfectly for my taste - they are flush with fender and under full load they get tucked in fender without rubbing. I want to get the same fittment with new wheels. If I order new wheels with 20x10, ET 35 and 295/30r20 tires would they fit? As per my calculations 3mm less offest should make the wheels stick out 3mm further and swapping from 275 tires to 295 tires should make the tires stick out 10mm further and in sum the new setup should stick out 13mm further comapared to my current wheels without any spacers. Because i have 15mm spacer on current setup the new setup without any spacers should then be sticking out 2mm less then current setup. Am i correct? Can someone please confirm?
      03-02-2023, 11:36 AM   #9
brad850csi
Drives: 16 F13 M6 Comp
I think middle or bottom.
As for offset, yes your calculations are correct but be aware that some tyres are wide and some are narrow.
Do you have pics of the rear at the moment - that’s a fairly aggressive setup and I’d like to see it!
      03-02-2023, 12:26 PM   #10
lukavergille
Georgia
206
First two pictures are under heavy load and there is no rubbing at all. I think the camber caused by the lower springs is helping me to get away with aggressive setup
      03-02-2023, 10:39 PM   #11
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
I have heard of guys running 295’s but I am not convinced they have zero wheelwell rub, but it might fit w/no issue. I get a little inner wheelwell rub with 285/35’s every know and then over dips at higher-ish speeds. But I clear all suspension and outer wheelwell.
I recently went with a 285/30 because the shop ordered the wrong set and gave me a discount after they mounted them 🤦🏽. It didn’t matter at the time b/c my prior set of R888r’s only lasted 6 months so I figured why not.
But the reason I’d steer clear of a 30 is it feels like you hit dynamite anytime I hit a pothole. Absolute night and difference between the 30 vs the 35. Happy shopping!!!
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
