2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds 2011-2015 F10 BMW M5 BREMBO Calipers
      09-06-2016, 04:32 PM   #1
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Sold
✓ Will Ship
I have a set of 2015 BMW F10 M5 BREMBO Brake Calipers for sale. They came off a M5 with less than 500 miles on them, as the owner went with the Carbon Brake setup right after he bought the car. These will fit 2011-2015 F10's with brake adapter for F10 axle. Selling for $1000.00 plus shipping and 3.5% PayPal fee if paid by goods and services option, or you can pickup locally.
I purchased these originally for my F10 retrofit Project, then another set came up with front AND rear calipers, so even though many people just retrofit the Front brakes, as the rear have been reported to be the same on F10 and M5's, I had the new front and rear set painted in a custom color so there was no downtime on my car.
As it appears people do not pay attention to pictures, be sure to notice there are some minor paint chipping on the calipers (they ARE used) These are all primarily on sections you cannot see when installed (you can observe this in detail on the 5th picture. It appears when they removed the caliper they laid it on its top) The only thing that is seen when installed are the ///M symbol on the sides, and the exposed areas look in to be very good shape, AGAIN, (see pics and ask if there is the slightest question). I can of course send close ups of any section if you like, just ask me.
I paid 1200 dollars plus shipping. The calipers are the same part number 2011-2015 on all M5s and thus interchangeable on 2011-2015 550 models with axle adapter and brake line. (Please verify your car with www.realoem.com) and axle adapter manufacturer if you are modding a non M5
If any of the minor road debris chips or removal chips bother someone, these can be painted for about 200 dollars. That is what I did with my other set was to have them painted before install even though they were in mint condition. 3 coats of paint and then with clear coat, as bmw uses just one coat of paint. The rims I have show off large areas of the calipers and I plan to put my car into car shows, so this mattered to me, but may not matter to many others.
BMW only puts one coat of paint on their calipers, so as soon as ANYTHING touches them, even removing the retaining springs, the paint flakes. Just a fact of life with BMW calipers and their stock paint work.
They run $1000.00+ piece on eBay ($2000 total) or more, plus another couple hundred for brake pad springs, bleed valve covers and so forth. So you are getting a DEAL on this pair for $1000.00! Again, if someone wants perfect calipers, these can be painted at a body shop for about $200 dollars. But any chips are mostly in areas you will not see when mounted.
I cannot emphasize enough how easily BMW OEM calipers chip.
These are in perfect mechanical working condition as they came off a car that was just purchased new. Then the owner decided to put the carbon fiber brake setup on his M5.
      09-06-2016, 06:00 PM   #2
AlpineWhite13
Drives: 2013 535i m sport.
How much are u asking?
      09-08-2016, 11:35 AM   #3
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Do you have the link to retrofit these on a 550ix?
      09-09-2016, 05:42 AM   #4
mikekilpatrick
You just need to purchase the adapters, which can be sourced on ebay, here on the forums or there is a Russian Gentleman that sells them shipped for 220.00
All parts available from www.getbmwparts.com Ask for Jason
Front Brakes:
Left Rotor 34112284101
Right Rotor 34112284102 Pads set 34112284869
Brake hoses 34322284318 each (2 needed, one per side)
Custom Caliper Bracket
Adapaters:
www.ebay.com/itm/252253422457
www.ebay.com/itm/272117762081
There is a Russian Gentleman that makes the Brake adapter for 220.00 Shipped
The caliper adapters from Russia are TOP NOTCH and at 440.00 for a front and rear set, a real deal. He even includes the bolts. Torque Specs on Caliper adapter bracket: М12-1.75 torque 115 Nm (~80 ft lbs),
Email for adapter is: tronik75@gmail.com
      09-09-2016, 11:38 AM   #5
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Front Brakes:
Adapaters:
Master Cylinder is Cross Compatible from M5 to 550
http://www.yoyopart.com/oem/12789525...336796729.html
Email direct is: tronik75@gmail.com
that yoyopart link is not correct. So all said and done this is going to cost 1200 just to get everything I need plus what you have?
      09-11-2016, 07:02 PM   #6
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Yup, sounds right. And 50% cheaper than a set from Brembo.
true, I am taking my car in on Wednesday for service. Running rich bank 1 and the dreaded oscillation so I would take the brakes off your hands but I have to wait to see what what the dealer says about the car.
      09-18-2016, 10:01 AM   #7
Viral
Drives: '06 330i
will these clear non-M5 wheels?
      09-18-2016, 05:37 PM   #8
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Cool, I understand. I have some things to do to my car as well and waiting until Oil Change is done under warranty in the next few weeks before I make the changes, so I completely understand. Let me know when you decide.
Update, Sold the car for a year newer LCI same color and mocca napa leather. and it is better in every category. Love it best choice I made this year but an expensive one.
      10-12-2016, 04:44 PM   #9
gabypr
gabypr's Avatar
Puerto Rico
150
Drives: Jet Black 2015 F10 535i
One quick question. Does the M5 rotors are compatible in a f10 535i? Would I need anything else? I love how they look and that are OEM. Thanks
CQuartz UK 3 Ceramic Coating | GeoShield Pronano 50% Ceramic Window Film | M5 M Perf Steering Wheel | M6 Comp Pkg Mufflers | M Perf Floor Mats | CF Spoiler | RW CF Quad Setup Diffuser | RW CF Front Lip | CF Trim | BMW Interior Leds | M5 343 Wheels | Pure Stg 2 Turbo
      11-29-2016, 05:31 PM   #10
mikekilpatrick
See Brake Forums for how easy these are to put onto F10 cars.
Adapters can be purchased Here:
'also we have another adapters for other cars
https://www.drive2.ru/o/tro-nik
write to us
email: tronikpart@gmail.com"
      12-23-2016, 09:15 AM   #11
IBOOSTU
Drives: 19 M5 COMP/21 M5 COMP FROZEN
WILLING TO SELL REARS ONLY? pm me !
      04-13-2017, 10:56 AM   #12
F10MS///
Drives: F10 M-Sport 2012
Still have it? Keen to buy..
      04-14-2017, 07:18 PM   #13
F10MS///
PM sent
      04-20-2017, 10:52 AM   #14
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
does this calipers come with brake disc, brake lines, brake pads etc.? or is just the caliber?
BMW f10 550i Msport
      04-20-2017, 04:17 PM   #15
F10MS///
Pm replied
      04-21-2017, 02:48 PM   #16
F10MS///
Kindly check mike. Tq.
      05-01-2017, 02:23 PM   #17
V10S85
Drives: BMW M5
I PM'd you
      05-14-2017, 06:52 AM   #18
mikekilpatrick
20 inch rims should provide the minimum clarance Brembo recommends for them
      05-14-2017, 07:16 AM   #19
mikekilpatrick
Here is a link to the set I had painted prior to install and they were brand new. Even just removing the Retaining springs on the calipers causes BMW paint to come off. They dont make them for super quality, just a 1 coat of paint over metal from BMW.
http://f10.5post.com/forums/showthre...1220017&page=3
      05-20-2017, 11:42 PM   #20
mikekilpatrick
If the Road chips and removal scratches in the areas that are not seen when mounted bothers anyone, I can have my body shop powder coat these to they will be resistant to road debris. BMW only puts one coat of paint on their calipers and Front CF spoiler, so unless you have them custom painted, they are supseptible to easy paint damage when on the car. Most people do not care if there are scratches in places where you can not see it when installed on car, but if that is something that is a concern to you, these can be painted to look absolutely perfect for about 200 dollars. Considering these run over $1100.00 a piece (2200.00 total just for calipers) plus the Brembo bleeder valve covers, Brake retainer springs and so forth, getting a set with less than 500 miles on them at 1k is a great deal. But if you are building a show car, then the custom paint work might be an option for you.
