2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Coolant leaking through the turbo lines in 550ix
      07-13-2016, 02:16 PM   #1
TheEngineer
TheEngineer's Avatar
Drives: 2011 BMW 550i xDrive
My Dealer just told me this. Has anyone else experienced this? What else should I do while the engine is taken apart to do this.
      07-13-2016, 03:56 PM   #2
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
Honestly, there's not much else you should do because it's pretty easy to get to the coolant lines on the turbos, not much you have to take off. You could replace all of the oil feed lines, but that is a little overkill depending on how much you want to spend.
Not that surprising that one is leaking with all the heat around the turbos. There's always going to be a weak line or two out there that will fail early because of heat.
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      09-08-2016, 02:38 PM   #3
Paul1994
Drives: 2018 BMW M4 comp -- BMW x5 G05
  [0.00]
I just ran into this and I am crying. I saw a DIY to fix and fixed one line, but had others that i could not see. The dealer is charging me around 3k for the repairs.. I am not happy about that. and my aftermarket warranty is not covering the hoses.
I am wondering now is this just going to be a common theme and maybe i should have bought the 535i..
