11-10-2020, 10:45 AM | #1 |
Rep 32
Bad Starter???
Hello All,
All of a sudden, my car refuses to start. I hear a loud click and that's it. I'm guessing the starter needs to be replaced, but what else could it possibly be? Any thought would be appreciated. Thank you. |
11-10-2020, 12:20 PM | #2 |
Rep 7,548
How old is the car's battery? And if this is for the 2005 545i listed under your name...you may want to ask over on the e60 5 series forum...they may be more familiar with issues going on with your car since a 05 545i is an e60 chassis.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-10-2020, 12:45 PM | #3 |
Rep 32
Sorry i forgot to mention, this is a 2015 550i with about 48k miles on it. Battery appears to be fully charged. It did this same thing last week, but it started the next day.
11-11-2020, 10:08 AM | #6 | |
Rep 32
Car Access System Fault code: 930730 Driver KL50L: current overload Fault code: INFO 930861 Secure motor pool at zv |
11-12-2020, 08:53 AM | #7 |
Rep 7,548
Fault code: 930730
1) Check line or plug connection between CAS and solenoid switch.
StradaRedlands4991.00 |
05-15-2021, 05:46 PM | #10 |
Rep 33
Drives: BMW 535I M SPORT
I had the same exact issue on my F10 it ended up bieng my starter at 109k miles. car refused to start with a full charged battery. All I heard was a clicking noise as well.
2011 535i M Sport l ER Chargepipe l BMS Intake l Megan Racing Mufflers l RVG Catless Downpipe Subscribe To My Youtube Channel!! https://www.youtube.com/channel/UCuR..._as=subscriber |
05-18-2021, 12:33 AM | #11 |
Rep 68
To those that have had starter trouble, do you regularly use the start stop? Curious about correlation.
OnlyGerman363.50 |
05-18-2021, 05:39 PM | #12 |
Rep 5,392
I believe there is one. My neighbor was a mechanic for the USPS and he said they replaced starters quite often on the mail delivery trucks. Even though they don't have automatic stop/start, they physically stop and start the trucks very, very often. I asked him if he thought the auto s/s would wear out the starter early and, in his experienced mechanic (he even owned a shop until his partner ran it into the ground) opinion he said most assuredly. Since then I haven't used the s/s at all.
02-08-2023, 08:19 PM | #13 | |
Rep 3,047
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
So I see your suggestions above, but I might as well be trying to decipher cuneiform alphabet. I guess I follow/understand just enough to get myself in trouble! So follow up questions based on your suggesstions: 1) Just wiggle the plugs at the CAS module under the steering column? These are directions I found: https://www.rpmmotorsport.net/pages/...l-instructions 2) I have a multimeter, but don't know which wires/terminals to check there? 3) How do I check the starter beyond the Foxwell tool check function. Is there another way to check? 4) Renew CAS means buy a new one or send it in to get repaired? Or is this some ISTA coding process? Where is the relay located, and can those just be swapped out? THANKS for any help. I don't want to just start throwing parts at it, and don't have anyone competent to take it to for diagnosis. Last edited by StradaRedlands; 02-08-2023 at 10:45 PM.. |
Tags |
battery, starter, starter motor |
