2010 2011 BMW 5 Series Forum F10 Low Tire: Stop Carefully |
04-29-2019, 02:23 PM | #1 |
Rep 4,048
So I keep getting this warning on my 2012 528i, for the drivers side rear tire. It initially did this once, but went away once I reset it (pressure was fine). Now it comes on and stays on even after I reset. Obviously something is wrong as I check the pressure and its fine.
Is there something wrong and what is the fix? I didn't think that there were any actual sensors or devices in the wheel, just the car sensing based on rotation. Please advise. Thanks |
04-29-2019, 02:48 PM | #2 | |
Rep 5,365
04-29-2019, 03:04 PM | #3 |
Rep 14,522
+1 on the battery failing. numerous members having the same issue in the past
04-29-2019, 03:46 PM | #4 | |
Rep 7,485
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-29-2019, 04:11 PM | #5 |
Rep 4,048
Excellent, thanks guys! I suppose you change the battery during a tire change? Should be fairly easy for the tire installation place to do? I may have to live with it for a few thousand miles more as my tires are in decent shape right now. LOL!
04-29-2019, 06:06 PM | #7 |
Rep 5,365
The batteries aren't serviceable. You will need a new sensor; or sensors. When you need new tires I would replace all the sensors as well.
04-30-2019, 10:34 AM | #8 |
Rep 4,048
I see, thanks. Does anyone know the part number? Is it the same for all 4 wheels, or different for front rear? Thanks again everyone
05-01-2019, 08:37 AM | #10 | |
Rep 7,485
I recommend saving all 3 of the sites below...because sometimes one or more may be down for maintenance just when you need to look up info: {EXAMPLE: you need #2 & #3 if you look up the TPMS on the bmwfans.info site...click link below for more details & info} http://bmwfans.info/parts-catalog/F1...rdc_ctrl_unit/
philipm78581.00 AlexL4.50 |
05-01-2019, 08:18 PM | #11 |
Rep 659
Ya know, I have never seen realoem down.
Anyway, sage advice. Might I add, for repairs, diagnostic and such use, www.newtis.info Please give thanks to Qsilver7 for his time and effort. |
05-02-2019, 09:16 AM | #12 | |
Rep 4,048
05-02-2019, 02:42 PM | #13 | |
Rep 7,485
05-04-2019, 09:23 AM | #14 |
Rep 342
The batteries tend to last ~8 years so if one failed probably time to do them all. You dont have to replace with OEM parts either. Shop around and get a good price on them, buy them and wait for your tire change to have them installed or even call your tire place (discount tire has a device that can communicate with the TPMS sensor) and see if they will check yours and cut you a deal if you buy with your next set of tires... The new ones will have to be reset to the car.
05-04-2019, 02:20 PM | #15 | |
Rep 247
05-05-2019, 08:42 AM | #16 | |
Rep 342
I believe the tire place can do it. They did it for my G37s so I would think they can do it for others.... but with BMW you never know... just give them a quick call and see what they say. |
philipm78581.00 |
05-05-2019, 04:42 PM | #17 | ||
Rep 7,485
This past December, I had new TPMS installed in my f06 winter wheel/tire set-up where the tires and sensors were purchased from Discount Tire but after installing sensors and mounting the tires to the wheels...the wheels weren't mounted onto the car at that time. I had to get other work done at another local automotive shop...and they were the ones that actually mounted the wheels...and activated and reset the sensors once all the wheels were mounted to the car.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-05-2019 at 04:51 PM.. |
08-13-2019, 08:49 AM | #19 |
Rep 4,048
For those that have purcahsed after-market ones, can you post which ones and from where? Tires are wearing down and I'll be ready to change in the Fall, so need to buy these now. Thanks
08-13-2019, 10:18 AM | #20 | |
Rep 7,485
I would recommend again, to look up the 11 digit BMW part nbr specific to your car, then type BMW xx xx x xxx xxx (where x = actual BMW part nbr) into a google search box. This should pull up enough vendors to see what the price range is for the type of sensors you need. Then compare those to any offerings local vendors you trust...and they may even price match. Also make sure that whoever mounts the sensors has a tool to activate them if they need to be programmed.
08-13-2019, 01:59 PM | #21 | |
Rep 4,048
https://www.tpmsdirect.com/BMW_5_Ser...12-04-hufm.htm Update/Edit: I contacted the seller and they confirmed that this will work...plug and play. I'll likely change my tires in a few weeks and will report back Last edited by BigKutta; 08-14-2019 at 03:51 PM.. |
