2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Thrust angle and crabbing.
      01-25-2019, 03:21 AM   #1
bgbQ8
Drives: 530i F10 2013
Hello guys.
My car seems to be pulling to the right for the past 6 months. I remember the pulling started to happen when I had to get the car in for a brake service to be done. Then I had to change 3 tires the fourth one was changed 1 month prior.
Around last month I started to notice that the car looked bent to the left which freaked me out since I thought The frame was bent too( never had any major accidents). The biggest crash I did was my rear right tire hitting a curb at 5 to 8 mph.
So I took the car to the dealer and they did an inspection which resulted in me having to replace both front thrust rod bushes and lower control arms. Then they did a 4 wheel alignment and the pull somehow got reduced a bit but came back a week later. the car still looks bent. I got an appointment with the dealer this week to work out what to do next.
Any help would be appreciated.
In the pics the car is parked straight. If u look at the left side it doesnt look straight. The thrust angle is measured to be 0.02- would that make the car to crab down the road?
EDIT : update
Got to the dealer and we came to the conculsion to get a frame/chasis inspection.
Gonna update once I get the final report.
      01-26-2019, 08:18 AM   #2
paul223
paul223's Avatar
Drives: F10
If you are talking about rear tires having different gaps in relation to rear top fenders (one of tire upper side looks more in towards body), it is normal. I thought the same that my car's rear wheel were out of alignment, but according to machine it was straight but visually looking at each side does not look straight.
      02-09-2019, 06:40 AM   #3
bgbQ8
UPDATE : turns out the chassis/frame is fine and the problem could be tires having radial pull.
      02-09-2019, 01:30 PM   #4
Easy enough to check. Swap the left and right front tires and see if the pull follows. The bad tire is the one that pulls; i.e. right pull = right front tire and vice-a-versa.
      02-09-2019, 03:04 PM   #5
bgbQ8
Yeah, they swapped the tires and the vehicle started pulling hard to the left instead of right.
Gonna get myself new tires tmw.
