2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Water Stain Inside Instrument Cluster
      06-04-2015, 08:24 AM   #1
mgattmch
Drives: 2015 650iX GC
Hi,
I have a few water mark stains (I guess from condensation?) on the inside of my instrument cluster. I know this is a sealed unit and there is probably no way to fix this short of a new instrument cluster ($2,500 I am told, not going to happen!). However, just in case, does anyone know if there is a repair service (or DIY solution) for this problem?
Regards,
Marcus
      06-04-2015, 08:40 AM   #2
493263
493263's Avatar
71
Drives: 2011 550i xDrive
Of course the dealer or indy shops will tell you to install a new unit because that's the safest route for them to go. You can open any of these sealed fixtures and instruments by using a high power blow dryer or baking it.
      06-04-2015, 04:28 PM   #3
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
It is easy to get the cluster out of the car, and a minute to remove the face plate and clean it. There are some You Tube videos about removing the F10 cluster. It is as easy as it looks. Once it's out, you'll see the TORX screws which hold the face plate.
Regards,
MWPos
      06-04-2015, 08:26 PM   #4
snj1013
Drives: 2011 528i
+1, I've had my cluster apart dozens of times. Piece of cake.
      06-05-2015, 02:42 AM   #5
mgattmch
Can someone direct me to a video showing how to remove the front cover/screen? I have found lots of videos showing how to remove the instrument cluster (very simple) but none showing how to get the front screen off for repair.
      06-05-2015, 08:29 AM   #6
493263
493263's Avatar
71
http://f15.bimmerpost.com/forums/sho....php?t=1039855
Here you go. It looks like you don't even need to use any heat since it's not sealed by glue.
      03-28-2018, 01:48 PM   #7
mgattmch
Thanks to the previous two contributors to this post I finally worked up the courage to remove the instrument cluster and clean off the condensation stains on the inside. Looks perfect now. However, the CEL is now on, even though the iDrive menu tells me everything is OK. Will post on how to set the CEL.
