2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Alarm going off
      03-02-2011, 03:33 AM   #1
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
Alarm going off
I have a problem with my alarm going off now and then, tonight it was at 4.00AM which is pretty irritating. Other times it has been going off it was nothing provoking it, it is parked outside the kitchen window so I have a good overlook over it.
Anybody else have the same issue? Its an original factory-installed alarm.
      03-02-2011, 03:54 AM   #2
Manas
Drives: F11 520D
It happened to me the other day but a few seconds after I closed it, I then realized that one of the doors was not properly closed.
Could it be the same situation in your case?
      03-02-2011, 06:24 AM   #3
Touring
Touring's Avatar
Norway
178
Hmmm, I will check, but it happes hours after I close the door, but I will keep that in mind!
      03-03-2011, 08:04 AM   #4
SpokenHands
Certified Car Nut
SpokenHands's Avatar
Drives: AMG GTC + RR Velar + 640d GC
Alarm sounding off for no reason
There are a couple of things you could check for
1. Obviously make sure your car windows/doors/sunroof is secured and not open
2. If your car is parked on an inclined driveway, or road with strong camber; it may be setting off the anti-theft algorithmn which is used to ensure alloys/car is not raised onto a flatbed truck and carted away. Park on flat ground and see if it goes off.
3. Most likely, there is a problem with your battery and it has a low or inconsistent voltage which needs to be investigated by your dealer. Are you having problems starting, or are you finding the drive jerky?
      03-03-2011, 11:10 AM   #5
Touring
Touring's Avatar
Norway
178
Thank you! It might be number two. Its so much snow now so the car is tilted when its parked. That might be it!!!
      03-03-2011, 11:18 AM   #6
ghueser
Drives: 2014 M5
Plus as the prior thread explains about the tilting mode of the alarm, it might be more sensative to wind blowing on the car. A big gust could fool the alarm into thinking that someone is tampering with the car, or trying to start the tow process.
      03-03-2011, 11:27 AM   #7
Touring
Touring's Avatar
Norway
178
Yes, that can be it. It windy in the wintertime. I better move to California or something.
