06-29-2012, 11:26 AM | #1 |
Rep 32
more HP from tuning
Has anyone installed this yet on here?
http://burgertuning.com/N20_BMW_performance_Tuner.html I contacted their rep and he said it is compatible with the 528 F10. What else is available that doesn't require you to send in EDU and can be removed easily if you need to bring the car to BMW for service? |
07-02-2012, 05:48 PM | #4 |
Frequent Flyer
51
Rep 415
I think the N20 is too new for people to comment on the tune. I have their tune on my 335i and can attest for their great build quality and superior customer support.
07-03-2012, 09:00 AM | #5 |
Rep 32
I'm thinking it must be too new as well. However, you have items available from Berger @ under $500 then you have Hartge and Kelleners that are $1600 for the same performance figures. I am hoping there will be something that will be the best bang for the buck that will allow you to simply install and remove when needed to take back to the dealer.
What are some folks experience with piggy back units and having to take back to the dealer for maintenance? |
07-03-2012, 09:06 AM | #6 |
Rep 8,830
Anything aftermarket will need to be removed before bringing it in for service. It might be ok if you are just taking it in for an oil change but if you are complaining about any motor issue they could potentially blame the tune for it and deny warranty. It all depends on your dealer. Some are more mod friendly than others.
With aftermarket piggyback tunes such as this offering from Burger Tuning expect to have some trouble shooting for early adopters. No matter what the vendor claims there will be things to iron out with tunes from these small companies. Its been going on for a long time on the E90/92 boards where there are tons of updates all the time to fix new issues that pops up. It could be from new bmw updates, weather changes or just new tune updates that doesn't jive with everyone's car but works on the car they used to tune. If you are expecting a "set it and forget it" type mod then i would hold off for awhile so they (and customers) could iron out the kinks. For those jumping into this then i would HIGHLY suggest you pick up the Bavarian Technic OBDII scanner as well. They finally have F10 support and this will allow you to see everything is going on with the car and the ecu. It will also help with troubleshooting and resetting any lights your car might throw. Alan
07-12-2012, 03:54 AM | #7 | |
Consultant
Rep 22
I settled for Kelleners and had been using it for a little over a month now. The power hike definitely made alot of difference, especially driving around town where the initial turbo lag was annoying. It gives an almost instant response while pulling smoothly to the redline. Daily usability has immensely improved and surprisingly more economical on fuel consumption too. The only downside in my opinion, is that it doesnt feel the declared 294hp. Maybe its so smooth to feel the kick i was expecting, but ive not brought it for a dyono test. I'm not a hardcore driver, so I'm not so fussy in squeezing every pony out of the engine. I can vouch for Kelleners, and IMO its money well spent. No regrets at all. |
07-14-2012, 01:31 AM | #8 | |
Rep 32
07-15-2012, 11:44 PM | #9 | |
Consultant
Rep 22
The only wish is that if I can boost it higher. You know, you can never have too much power. The car is made to handle much more power, so I guess this tuning is just far below the treshold of the car's limit. |
07-16-2012, 02:11 PM | #10 | |
Rep 32
