2010 2011 BMW 5 Series Forum F10 BMS JB Stage 1......Help Please |
02-02-2016, 11:40 PM | #1 |
Rep 83
Hey All,
So I finally bit the bullet and purchased the BMS Stage 1 for my N63 550i. Everything went as planned - no codes/CEL, however, I do not know where to place the actual BMS box. Upon placing the BMS box on top of the ECU (in the cowl)- the outer plastic bulge pushes my hood up in the corner when shut. Currently I have the BMS box laying close to the wire entry point/main connection to the ECU until I figure out a better location. Any suggestions? Also - how many ECU "adaptations" are needed before the car is running at 100%? Difference is subtle at this point. Thank you! |
02-03-2016, 01:02 AM | #2 | |
Rep 2,416
2011 550i RWD 60-130 7.35
02-03-2016, 02:27 PM | #3 |
Joint Chiefs of Staff
24193
Rep 190,805
Do a log so we can check if everything is good
Here is what to expect with map 1
02-05-2016, 10:46 AM | #4 |
Rep 83
Bad Black the Legend! Thank you for the response. My concern is that if I drop this little black box next to the ECU that it will get rattled around and potentially cause an issue. Any ideas on mounting? Should I Velcro/secure this piece?
02-05-2016, 12:52 PM | #5 |
Rep 2,416
you can do that of course.
02-05-2016, 01:42 PM | #6 |
Rep 171
I placed mine inside the cavity where the hood hinge is (passenger side). There is a flat spot that you can place it there side way. There is enough clearance after close the hood even though it looks tight..
02-05-2016, 07:21 PM | #7 | |
Rep 736
I used a zip tie to fasten it in tight in that spot |
