2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Spedo/Tach lights out
      03-05-2017, 01:49 PM   #1
ted99
Drives: former i3>330e, 528i>X5 40e
The lights behind the circular spedo and tach are out on my 2015 F10 528i. The other display lights with letters and symbols when I turn car on are working. The "dash illumination dial" has no effect. Looked in the fuse box in the trunk and no visible indication of blown fuse (I presume that these solid color fuses would have a discoloration if blown). Any ideas?
      03-05-2017, 03:00 PM   #2
zugellos
Drives: 535i M-Sport
You'll need to pull the appropriate fuse out and take a closer look.
Look for a small metal piece within the fuse...if it is broken apart then it is blown.
      03-06-2017, 12:09 PM   #3
nhrider
Drives: 2012 535 Xl
2016 535Xi  [0.00]
You are aware that there is another fuse panel located behind the glove box?
I don't know which panel the offending fuse resides in, but I thought you should be aware.
In my experience, It can be very difficult to diagnose a blown fuse without removing and examining it, or using a multi meter.
      03-06-2017, 12:49 PM   #4
ted99
^^^ No, I was not. When I looked at the trunk fusebox, I found a folded paper with the fuse numbers and sizes, but no identification of which served the dials. Where can I find a diagram that identifies which fuses serve different functions?
      03-06-2017, 04:44 PM   #5
BigKutta
BigKutta's Avatar
65
Drives: 2012 528i
2012 528i  [0.00]
2012 BMW 528i  [0.00]
Take it to the dealer.
      03-06-2017, 06:39 PM   #6
wcr3d
Drives: 2013 535i XDrive M Sport
+1
