01-23-2012, 02:20 PM | #1 |
Rep 111
Trunk Kit
What was included in your trunk kit when you ought your 5 series? I only recieved the tow hook and screwdriver. Is that all that comes with it? Or was there suppose to be more?
2011 535i (Black Sapphire)
2010 M3 Coupe (Alpine White) 2009 M6 (Jet Black) 2001 525i (Jet Black) |
01-23-2012, 02:49 PM | #2 |
Rep 3,016
You should also have the wheel lug bolt adapter, otherwise you'll be in trouble if you need to change a tyre. It's item 8 here: http://f10.5post.com/forums/showthread.php?t=637242
The extra spaces are for the 1st aid kit and warning triangle, but they're only supplied with EU spec cars. |
01-23-2012, 02:58 PM | #3 |
Rep 111
Thanks man. Ama check it out with the dealership and see why those parts are missing.
01-23-2012, 03:31 PM | #4 |
Rep 70
For me, the lug bolt adapter was not placed in the tool kit, but instead in the packaging that those special lug bolts came within. They put the other bolts they removeed in that package apparently as well. It took me a month to figure this out (not that I needed it, but still....). May save you some time.
If your car is US spec, you will not find any other item in your tool kit other than the ones you already have and the lug bolt adapter.
2011 550i Space Gray + Oyster/Black
2000 520i Titanium Silver + Gray Leather European 70K km - keeper 1999 328i Orient Blue + Gray Leather 45K miles - retired |
01-23-2012, 04:05 PM | #5 | |
Rep 519
You can search other threads on why the kit is so barren in the US, and where to source the components. |
01-23-2012, 04:33 PM | #6 |
Rep 4,047
I am pretty sure I dont have a lug adapter in my 2012 528i, only tow hook and a useless screwdriver. I'll check though...
01-23-2012, 05:25 PM | #7 |
Rep 70
I did not ask for the anti-theft lugs, I did not pay anythign extra for them. So unless they are somehow standard on 550's and optional on the rest, anyone else in the US should be getting them too...
Easy to identify; look at them on the mounted wheels, and see if one differs from the rest with a star-ish pattern...
01-24-2012, 05:01 AM | #8 | |
Rep 3,016
