2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Anyone Help Me Code/Clearing error code With E-Sys?
      04-19-2016, 05:04 PM   #1
Googlyamnesiac
Googlyamnesiac's Avatar
Drives: 2013 F10 520D
My e-sys cable is coming soon and my main focus initially is to try and clear the error code I accidentally threw when changing an interior bulb.
Can anyone point me in the right direction or offer any remote coding to do it for me?
I've got a 2013 F10 (520D) and i'm in the UK.
Thanks!
      04-21-2016, 05:23 AM   #2
Googlyamnesiac
Anyone? :-(
      04-21-2016, 05:45 AM   #3
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You use the external transmitter in E-sys to clear some codes, but not sure whether that applies to light bulb errors.
Did you change the type of bulb?
      04-21-2016, 05:52 AM   #4
Googlyamnesiac
yeah the bulb is fine - it's moaning about passenger airbag - found a thread on here that explained it was a blown fuse, which I replaced. Some say the warning goes away, others say it sticks and needs to be cleared. I just want to clear mine but not sure what tool I use with my e-sys cable....?
      04-21-2016, 05:56 PM   #5
Almaretto
Almaretto's Avatar
2374
ENET cable. E-sys is a program.
The only clearing e-sys will do is through External Transmitter.
Double click transmitter → Predefined Services (scroll to bottom of list & select) → Hit connect → hit send. All set
For clearing errors and diagnostics, other tools include Toolset32 with INPA or Rheingold.
Not sure the following applies, but after flashing ASCM, to lock airbag, you would do the following:
E-Sys Transmitter:
1) Click "External Applications" in the left menu.
2) Click "External Application"
3) Double-click "Transmitter"
4) Double-click "ACSM verriegelung_schreiben"
Tool32:
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\ACSM4.prg
4) In the "Select Job: F01" window, select steuern_verriegelung_schreiben
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
