09-20-2023, 09:34 AM | #1 |
Coal Troll
151
Rep 326
F15 wheels on F10
Has anyone used F15 wheels(style 469) on their F10 with m5 spec tires (265/295)??
I cant find photos anywhere of someone doing it previously.
My hybrid burns Diesel & Oil
deleted F10 535d |
09-21-2023, 02:00 PM | #2 |
Rep 2,352
I think they'll be challenging to make fit well without quite stretched tyres.
Stock 19" or 20" wheels are 8.5" 33mm front and 9" 44mm rear. People often run 10-12mm spacers on the front and 15-20mm spacers on the rear with the stock 245 and 275mm wide tyres. These 469m wheels are 10" 40mm front and 11" 37mm rear. 245 and 275 wide tyres aren't rated for 10" and 11" wide wheels - 9.5" and 10" max. 255 and 295 wide tyres could work, they are rated for 8.5"-10" wide and 10-11" respectively. I think the 295 should work fine as people on 343m wheels with an offset of 34mm can run 285 but slightly rub on 295s and you'll be 3mm further in, but it will be close. 285s aren't rated for 11" wheels, only 9.5"-10.5" and in my view the fitment on the F90 M5 of 285s on a 10.5" wheel looks quite stretched. Lastly, at the front you'll be a little bit sunken in and will probably want to run around 10-15mm spacers with the 255 tyres. If you really like them you could buy a set and become friendly with a local tyre shop and hope they'll do a few test fitments or keep some old tyres when another customer has some swapped out.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
09-29-2023, 12:24 AM | #3 |
BMW enthusiast since 2004
373
Rep 190
11" et37 will fit rear with 275/30 by just. Wider tire will not fit. And front will need spacers.
This is my f10 with mentioned setup. Last edited by zener; 09-29-2023 at 12:31 AM.. |
09-29-2023, 10:37 AM | #4 |
Coal Troll
151
Rep 326
What tire size are you running up front?
deleted F10 535d |
