02-15-2015, 08:02 PM | #1 |
Rep 273
Drives: 2012 BMW 535i, 2018 BMW M3 CP
EDC Delete question
A few question for those of you that are running KW coilovers with the EDC delete module.
1. Does is completely disable the EDC control inside the car? Reason I am asking is that EDC control has several settings, most of them suspension related. However there are 2 which are not completely just suspension related. Sprots + which I use a lot and ECO. I'm considering going the coilover route but did not want to lose those functions. Seems like my car is fastest when i have it in sports mode, manual, with sports + activated using the EDC module. 2. Instead of using the edc delete, can you have it coded to remove any errors thrown. Is this a better option? Any info on this will be appreciated. Thanks! |
02-16-2015, 10:41 AM | #2 |
Rep 29,202
I don't have EDC, but I'd assume the EDC delete module only eliminate the error codes, and not the actual functions of the EDC buttons in the car.
02-16-2015, 08:03 PM | #3 | |
Rep 273
Can any other member that is running the KW coilovers with EDC delete confirm this? |
02-16-2015, 08:13 PM | #4 |
Rep 14,521
I inquired about the KW V1's and they said I needed the EDC module even tho I don't. Have EDC to eliminate the error codes that will pop up.
02-17-2015, 12:30 AM | #5 |
Rep 95
Its my main concern as well. Sport and sport plus mode does give better throttle response as compared to comfort mode with traction off and and manual/sport shifting.
I highly doubt the functions are retained because I believe the EDC control is disconnected when the shocks are replaced. |
02-17-2015, 01:11 AM | #6 |
Rep 291
Back about 6-7 months ago when I was contemplating getting these same coilovers, a rep from KW said I wouldn't be able to run these at all.
That's why I had to opt for the H&Rs. |
02-17-2015, 10:52 AM | #7 |
Rep 29,202
Weird, did he say why?
02-17-2015, 12:22 PM | #8 | ||
Rep 273
Thanks for the feedback. I currently have H&Rs and it looks like I might have to stick with it. Wish they offered a sleeve kit that utilized the stock shocks. |
02-17-2015, 01:21 PM | #9 |
Rep 29,202
You don't. I don't have EDC and I've got KWv3 without the module.
02-17-2015, 02:33 PM | #10 |
Rep 14,521
03-12-2015, 12:16 AM | #11 |
Rep 273
Just a quick update on this thread. I ended up installing the KWv2s with the EDC delete module.
I am happy to report that the edc control in the car is still fully functional and I am still able to switch between all the modes with no issue. The sports + and ECO mode still are functional for the drive trian and traction control options . The only thing that obviously will not work is the Electronic dampening. |
03-13-2015, 08:28 PM | #12 | |
Rep 14,521
03-13-2015, 10:38 PM | #13 |
Rep 182
Drives: 2015 BMW 650i GC
How does the ride compare to before? Played with the settings on the KW yet?
